How Can a Secondary School Student Solve Schrödinger's Equation?
  • Context: Undergrad
  • Thread starter Thread starter misogynisticfeminist
    Schrodinger's equation
The discussion revolves around how a secondary school student can approach solving Schrödinger's equation, focusing on the mathematical aspects and foundational concepts necessary for understanding this equation in quantum physics.
  • Homework-related
  • One participant expresses a desire for a step-by-step guide to solving Schrödinger's equation, indicating their current mathematical skills are limited to basic differentiation and integration.
  • Another participant mentions that Schrödinger's equation is a difficult non-linear differential equation and suggests looking up the "RKB approximation," which is challenged by another participant who corrects it to "WKB."
  • Several participants recommend starting with simpler cases, such as the infinite square well, which is often covered in introductory quantum mechanics texts.
  • One participant notes that the Schrödinger equation can only be completely solved for hydrogen-like atoms, while approximations are necessary for more complex systems.
  • Another participant emphasizes the importance of understanding boundary conditions and suggests that the time-independent Schrödinger equation simplifies in the context of the infinite well.
  • There is a discussion about the harmonic oscillator and finite potential wells, with some participants noting the complexity involved in these cases.
  • One participant advises against delving into advanced topics like the WKB approximation until the student has a stronger foundation in differential equations.
  • Another participant highlights the importance of understanding wavefunctions and their context in wave mechanics and electromagnetics.
  • One post includes a LaTeX representation of the Schrödinger equation, but it is noted that the formatting did not work properly for some participants.
Participants generally agree that Schrödinger's equation is complex and that simpler cases should be approached first. However, there are differing opinions on the appropriateness of discussing advanced topics like the WKB approximation at this stage, and some participants challenge each other's claims about the nature of the equation.
There are limitations in the discussion regarding the prerequisites for understanding Schrödinger's equation, including the need for knowledge of differential equations and boundary conditions. Some participants express uncertainty about the classification of the equation as non-linear.
This discussion may be useful for secondary school students interested in quantum physics, educators looking for insights into teaching Schrödinger's equation, and anyone seeking to understand the foundational mathematical concepts related to quantum mechanics.
Hi, I'm quite new to quantum physics, and I know that the Schrödinger's equation should be at the quantum physics section but I was wondering if anyone can guide me into the mathematical part of it. I'm only a secondary school student, and can do differentiation and integration. (definite integrals, product/quotient rule etc.) the very basic ones.
A Step-by-step guide on the mathematical aspect to solve Schrödinger's equation would be very very much appreciated thanks...
Schrödinger's equation, in general, is a very difficult non-linear differential equation. Look up the "RKB approximation" in a good quantum mechanics text. It is actually a variation of the "perturbation method" which is covered in advanced d.e. texts.
This whole tex thing isn't working out for me. Do a google search for "infinite square well" and you will come up with the classic first example that most students ecounter with the equation. From there, look at the finite square well and simple harmonic oscillator.
shrodinger's equation involves solving partial differential equations. It can only be completely solved for the hydrogen and hydrogen like atoms, because the helium atom for example has 2 electons and the nucleus. It would be like trying to solve the differential equation for a 3 bodied system, which has never been solved. Once you go past the hydrogen atom, approximations are used. The time independent shrodinger equation solution for the hydrogen atom is just a function of sines and cosines.
Go easy guys
Yeah the Schrödinger equation is hard, but there are some simple 1-D situations where its readily solvable. Like theFuture said, look for the infinite square well which is the easiest case. This is also done in probably all introductory quantum texts. Its also done on most texts that deal with "Modern Physics" which is usually a sophomore level course which introduces some ideas from modern physics.
misogynisticfeminist try solving the Schrödinger equation for yourself, in the case of an infinite well, before you look anywhere. So consider the Schrödinger (time-independent, 1-D):
[tex]\frac{-\hbar^2}{2m}\frac{d^2 \psi}{d x^2}+V\psi=E\psi[/tex]
Where, for the infinite well, the potential is:
[tex] V(x)= \left \{ \begin{array}{col}<br /> 0, \ if \ 0\leq x \leq a \\<br /> \infty, \ otherwise<br /> \end{array}\right[/tex]
Thus the Schrödinger equation only makes sense inside of the region [0,a], so it simplifies to
[tex]\frac{-\hbar^2}{2m}\frac{d^2 \psi}{d x^2}=E\psi[/tex]
or
[tex]\frac{d^2 \psi}{d x^2}=-{k^2}\psi[/tex]
where [tex]k\equiv\frac{\sqrt{2mE}}{\hbar}[/tex]
Or to make it just a little more familiar to a beginning calc student
[tex]{\psi^''}=-k^2\psi[/tex]
You have probably even seen this form, play with it, try to find solutions (remember you need a linear combination of 2 independent solutions and the two unknowns are solved by boundary conditions. What do you think the boundary conditions should be?).
Good Luck,
Kevin
Thanks, homology. That's what I was trying to get up but the tex wasn't working out for me. This can also be "extended" to a situation where outside of the well there is a finite potential. Another interesting, and solvable case is the simple harmonic oscilator.
Sure, I didn't mention the others since misogynisticfeminist expressed their rudimentary calculus skills. The harmonic oscillator involves Hermite polynomials or ladder operators both of which can seem a bit strange or daunting at first. The finite well can also be difficult since it involves breaking up the DE into three parts and matching boundary conditions, considering bound and free states and so on. But you're right of course.
Kevin
What's nonlinear about it? Both superposition and homogeneity are satisfied.
You mean "WKB", right?
misogynisticfeminist,
I think you should probably put off the Schrödinger Equation until after you've learned about differential equations and how to solve them given a set of boundary conditions.
Also, please don't look at things like the WKB or Mean Field approximations just yet. You will learn all about those at college/Grad School.
Finally, I should add that a "purely mathematical" knowledge of different solutions to the SE, while useful for showing off to friends, is otherwise quite wasted. To really appreciate what is happening with the SE, it is important to understand what a wavefunction is (preferably in the context of some previous wave mechanics experience) as well as understand basic electromagnetics so things have a context.
The SCHROD-Equation is:
The following code was used to generate this LaTeX image:
[tex]H\psi=E\psi[/tex]
It depend on The Hamiltonian operator
  • · Replies 21 ·
