Best Way to Boost Performance on my Old Dell
  • Thread starter Thread starter Saladsamurai
    Boost performance
The discussion revolves around optimizing the performance of an old Dell Dimension PC, specifically focusing on hardware upgrades and software adjustments. Participants explore various approaches to enhance the system's speed and responsiveness, considering both memory upgrades and alternative operating systems.
  • Homework-related
  • One participant suggests upgrading the RAM from 256MB to a maximum of 2GB, noting that the current performance is severely hindered by the low memory.
  • Another participant emphasizes that Windows XP can be slow with only 256MB of RAM and recommends upgrading to at least 1GB for better performance.
  • There is a discussion about the compatibility of RAM types, with some participants clarifying that the motherboard only supports 2GB total, requiring two 1GB sticks instead of 2GB sticks.
  • Several participants propose using lightweight Linux distributions like Puppy Linux or Xubuntu as alternatives to Windows XP, arguing that these can significantly improve performance on older hardware.
  • One participant mentions that upgrading to an SSD could improve performance, especially for software that requires high data transfer rates.
  • Another participant shares a series of Windows XP tune-up steps aimed at optimizing system performance, including disabling unnecessary startup programs and managing the pagefile size.
  • Concerns are raised about the graphics performance, with questions about whether the slow response is due to the CPU or GPU limitations.
Participants generally agree that upgrading the RAM is essential for improving performance, but there is disagreement regarding the specific RAM configuration and the potential benefits of switching to a Linux operating system. The discussion remains unresolved on the best approach to enhance graphics performance.
Limitations include the uncertainty about the exact performance improvements from suggested upgrades and the varying effectiveness of different operating systems on the hardware in question.
This discussion may be useful for individuals looking to optimize older computer systems, particularly those with limited resources or those considering alternative operating systems for better performance.
Saladsamurai
I am contemplating a new PC build, but I feel that since I am so neurotic about details, it is not going to happen for quite some time. I need to put a lot more research into it. But for the time being, I would like to maximize the performance I get out of my old Dell dimension. The specs right now are disgusting:
Intel Pentium 4 CPU 2.8 GHz, 256MB RAM
I went to Crucial.com and did a system scan to see what kind of RAM I need. I was surprised to see that I can still buy it. The scan reported the following:
Maximum Memory Capacity: 2048MB
Currently Installed Memory: 256MB
Available Memory Slots: 1
Total Memory Slots: 2
Dual Channel Support: No
"Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot. (not to exceed manufacturer supported memory"
I am going to go with 2 x 2GB RAM and I think there should be a great increase in performance.
Right now, things are very slow. When I right-click on "My Computer" and then click the "Properties" selection it takes quite literally 3-4 secinds for the properties window to pop up. Same thing when I click the "Start" menu...3-4 seconds to pop up.
I recently wiped the HDD and reinstalled only the OS (WinXP Home) and MS Office. I have not completely ruled out a virus, but it seems unlikely since I wiped the HDD about 2 months back and have not knowingly visited any sketchy sites.
Anyone have any final suggestions to bring new life into my Dell aside from the RAM upgrade?
ALSO: I notice that when I click on a window (on the side pane) and drag to another spopt on the screen, I can literally see the vertical re-write. That is how slow the graphics respond. Is that a function of the CPU? Or solely the GPU?
Computer science news on Phys.org
Just buy the RAM, I'm amazed windows even runs in 256Meg !
are you sure? 4 GB is not supported by your motherboard, only 2 GB total, so you need two 1 GB sticks,
DDR type. Most ram is now DDRII and DDRIII, so have to look for DDR
as far as the graphics, it's hard to say. Upgrade ram to at least a gig total, and you should see a performance increase.
Use puppy Linux...it works blazing fast on ancient 64 mb systems also.
Anyway, you should try Xubuntu (I recommend this for your purposes)...it should work very well with your configuration.
You should also learn that in an old system, if you can change to a free software to make it blazing fast, why buy additional hardware?...and trust me it's easy, I can give you technical support and whatever you need to know for the installation...but if you fall in a real issue (usually this does not happen), you got to goto the Ubuntu community to get help. You also get paid technical support from Canonical which will be cheaper than buying a new hardware.
A DDR ram right now comes pretty expensive...you should know that.
I remember back in the day when people installed winxp on a win 98 machine with 64 mb ram, ie loaded slower than aol.
I agree, linux does memory swap, so don't even had to buy ram, although it would help. Memory swap basically borrows some HD space for ram, but at a cost of bus speed. Still should run faster than winxp.
Oops, you are right. I meant 2 x 1GB. How did you know that it only supports 2GB (function of the OS?)?
Anyway, $78 (USD) does not seem too bad.
Saladsamurai said:
I am contemplating a new PC build...
https://www.physicsforums.com/showthread.php?t=365677"?
Your proc is fine. Your miniscule amount of RAM is what's disgusting (and slowing you down).
2 GB is fine. Just do it!
Ensure you keep at least 20% of your HDD free.
That depends on how busy your CPU is paging RAM on and off your hard drive. Bump your RAM to 2 GB, first, then reassess. If there's no change in speed, spend $70 on a graphics card.
Best bang for the buck is RAM. Max it out, very cheap.
The other thing is your intended usage. Different types of software and usage-patterns will load different areas of the computer. You need to be very specific on what kinds of software you're using. Things with lots of data-transfers such as large graphics, video or databases are mainly limited by disk-speed. Getting an SSD will improve performance significantly.
if you are using Windows XP, there are a few "tune up" steps that I always do (in this order):
1) type msconfig.exe into the Run box, go to the Startup tab, and turn off anything that is not a device driver or part of windows itself; this will include "quick starters" for Adobe Acrobat, Quicktime, etc.
2) remove anything from Startup folder that you don't really need
3) in Windows Explorer, right-click over the C: drive and select the option to turn OFF indexing of files on your hard drive "for all folders and files"; this will take awhile to mark all the files; tell it to continue no matter what it asks you
4) in Windows Explorer ,right-click over the C: drive and select Properties, then clean the disk of temp files and remove all restore points except the most recent one
5) defrag the drive (Control System...Administrative Tools...Computer Manager).
6) in Control Panel, open the System applet, go to the Advanced tab and change the pagefile size to user-managed; set both the minimum and maximum sizes to a large number such as 2048 (or whatever maximum the software suggests); this prevents the pagefile from constantly resizing itself and will help prevent future disk fragmentation
All of this will usually noticeably speed up an older computer. And as everyone else noted, get more RAM!
9K
  • · Replies 16 ·
