Changes in planet orbits as a star (eg. the Sun) decreases is mass.
The discussion revolves around the effects of a star's decreasing mass, specifically the Sun, on the orbits of planets. Participants explore concepts from both relativity and Newtonian mechanics, considering how mass loss influences gravitational effects and orbital dynamics.
  • One participant likens the Sun's mass to a heavy ball on a trampoline, suggesting that as the Sun loses mass, the distortion of space-time decreases, potentially causing planets to move away.
  • Another participant asserts that Newtonian mechanics also predicts changes in planetary orbits due to mass loss, indicating that relativity is not necessary to understand the phenomenon.
  • Some participants mention that the actual change in Earth's orbit due to the Sun's mass loss is minimal, estimating an increase of about one centimeter per year.
  • There is a challenge regarding the implications of gravitational waves and their effect on orbital decay, with some participants questioning how this fits with the expected increase in orbit radius due to mass loss.
  • Several participants express confusion over differing interpretations of gravitational effects, with some asserting that the radius must increase while others suggest it could decrease under certain conditions.
  • One participant emphasizes the need for clarity on how gravitational wave radiation might lead to a decrease in orbital radius, despite the general expectation of an increase due to mass loss.
Participants express a mix of agreement and disagreement. While many agree that the orbit radius should increase as the Sun loses mass, there are competing views regarding the implications of gravitational waves and the potential for orbital decay. The discussion remains unresolved with multiple perspectives presented.
Participants highlight limitations in their understanding of how different theories (Newtonian vs. General Relativity) might yield contrasting results regarding orbital changes. There is also mention of the need for further clarification on the role of gravitational waves in this context.
Jus
Hi,
I'm actually a Design Engineer but I find the topic of Relativity extremely interesting and I was wondering if somebody could give me some guidance on this.
If Planets and Stars (due to their mass) 'warp' Space-Time then this means that our Sun distorts the fabric of space just like a heavy ball on a trampoline... Have I understood that right?
Ok, presuming that the above is correct, the orbits of the planets around the sun follow this distortion just like a ball rolling around a sink bowl... Does that sound right?
Again assuming I've understood the above points correctly, if the Sun is decreasing in mass all of the time then clearly the amount of distortion caused by the mass of the Sun on the fabric of space is decreasing... Does that sound right?
If all of the above is true, then wouldn't this mean that the planets following the path of the distortion (the balls rolling around the sink) would actually be moving away from the Sun as the 'sink' is effectively becoming slightly flatter due to the reduction in mass of the Sun?
Sorry if this sounds like a stupid question but it's been bothering me for the last few days!
Thanks in advance.
Jus
Yes, but you don't need relativity to arrive at this result. Newtonian mechanics says the same thing will happen.
Yes planets are moving their orbits as sun losses mass. But numbers are almost insignificant. When you add both solar winds and mass-energy conversion of sun, I think that you get about one Earth's own radius increase in Earth's orbit over entire life of sun so far.
Thanks for the answer. Sorry if it sounded like a stupid question, I didn't realize that the change in Orbit would be so insignificant.
The sun losses about 10^-13 of it's mass/year
This increases the Earth-Sun distance at the same rate.
But since the Earth-Sun distance is 150million km this is only about 1cm/year
heldervelez said:
On the contrary !
Everyone believes that the orbit radius must increase (even I do !)
How to explain the http://en.wikipedia.org/wiki/Gravitational_wave#Orbital_decay_from_gravitational_radiation"?
The orbit must vary in the same way as the conditions are similar (loss of mass/energy and non relativistic velocities).
We say: radius increase.
Other say: radius decrease.
Why ?
Consider the Earth orbiting the Sun. What would happen to the distance between the Earth and the Sun if the Earth's kinetic energy were gradually siphoned off?
I say : radius increase (and We say as seen above).
How should I understand the 'assumed' orbit decay due to radiation of gravitacional waves (masss loss) ?
No Newtonian gravity, or, equivalently, Kepler's third law, can be used to show that the distance decreases. I would do this, but, right now, my three-year-old is demanding that I read to her.
I agree with you George Jones and I have no need to see a 'proof'.
My surprise is that under GR we can not have such a different result.
Newtonian is an approximation of GR then I am prepared to sentences like this:
the rate of increase of radius on GR is more (or less, not important to the discusssion) than under Newtonian gravitation.
but never like this:
under Newtonian: increase of radius ; under GR decrease of radius.
I can not understand such a different outcome.
  • · Replies 0 ·
  • · Replies 51 ·
  • · Replies 81 ·
10K
