Null geodesics of light from a black hole accretion disk
This discussion focuses on solving the equation for null geodesics of light emitted from a rotating black hole accretion disk to an observer at infinity. The equation of interest is d²u/dφ² = 3u² - u, where u = 1/r. Participants clarify that this second-order equation can be transformed into two first-order ordinary differential equations (ODEs) by defining p = du/dφ, leading to the system: du/dφ = p and dp/dφ = 3u² - u. The discussion also highlights the need to adjust the initial gradient (du/dφ)em = -uemtan(E) to find the correct angle E for accurate light path estimation.
  • Understanding of differential equations, specifically second-order and first-order ODEs.
  • Familiarity with the concept of null geodesics in general relativity.
  • Basic knowledge of black hole physics and accretion disks.
  • Proficiency in using LaTeX for mathematical expressions.
  • Study the derivation of null geodesics in rotating black holes using the Kerr metric.
  • Learn about the numerical methods for solving ordinary differential equations (ODEs).
  • Explore the physics of relativistic line smearing in black hole spectra.
  • Investigate the implications of light bending in strong gravitational fields.
Astrophysicists, theoretical physicists, and students studying general relativity, particularly those interested in black hole dynamics and light propagation in curved spacetime.
Favicon
Sorry I don't know latex so this may look a little messy.
I'm trying to solve the equation for null geodesics of light traveling from a rotating black hole accretion disk to an observer at r = infinity. The point of emission for each photon is given by co-ordinates r, phi where r is radial distance from centre of the black hole, phi is azimuthal angle around the accretion disk (phi = 0 is defined to be the tangent point). The problem is stated as follows:
"Light travels on null geodesics given by the solution of the equation
d2u/dphi2 = 3u2 - u
where u = 1/r. The full paths can be found by integrating this from u=1/rem, phiem to u = 0 (r=infinity), phi = 0. This requires varying the initial gradient (du/dphi)em = - uemtanE until the correct solution is found for an angle E = E' + theta, where E' is the 'straight line' angle, and theta is the additional deflection from lightbending as the photon travels from rem to infinity. Explore the size of theta to estimate where the straight line approximation may break down."
I've also been told that to solve the equation I need to split it into two 1st order ODEs, but I'm not sure how to do that.
I'm really struggling just to try and understand the description, let alone solve the equation. Please could someone explain to me what this means and how I can extract the light paths from the given equations?
I learned latex when I joined Physics Forums. See
https://www.physicsforums.com/showthread.php?t=8997.
d2u/dphi2 = 3u2 - u
where u = 1/r.
But this equation is for null geodesics of non-rotating black holes. Is this what you want to do?
This second-order equation can be reduced to a pair of first-order equations by setting [itex]p = du/d\phi[/itex], so that [itex]dp/d\phi = d^2 u/d\phi^2[/itex]. Consequently,
the second-order equation is eqiuvalent to
[tex] \begin{equation*}<br /> \begin{split}<br /> \frac{du}{d\phi} &= p \\<br /> \frac{dp}{d \phi} &= 3u^2 - u.\\<br /> \end{split}<br /> \end{equation*}[/tex]
Thanks for the latex tip.
Yes it probably is a non-rotating black hole. I'm actually writing a program to produce the expected line spectrum from a black hole, but the description I've been given (to explain the physics of relativistic line smearing) isn't very clear so when it talked about the motion of the accretion disk I assumed it meant the black hole itself was rotating.
[tex]\frac{du}{d\phi} = p[/tex]
[tex]\frac{dp}{d\phi} = 3u^{2} - u[/tex]
So now I have
[tex]\frac{du}{d\phi} = p_{em} = -u_{em}tan(E)[/tex]
and have to vary E? But I still can't see how I'll know when I've found the correct value for E.
