Angular acceleration and it's mass dependancy
The discussion centers on the relationship between angular acceleration and mass dependency in the context of a wooden door being closed by a constant force. The key conclusion is that if the door's mass is quadrupled, the angular acceleration decreases by a factor of four, resulting in the time required to close the door doubling from 2 seconds to 4 seconds. This is derived from the formula for angular acceleration, which states that angular acceleration is torque divided by moment of inertia, and the application of constant acceleration equations to circular motion.
  • Understanding of angular acceleration and torque
  • Familiarity with moment of inertia concepts
  • Basic knowledge of kinematic equations
  • Ability to apply principles of circular motion
  • Study the relationship between torque and moment of inertia in rotational dynamics
  • Learn about the principles of angular motion and its equations
  • Explore the effects of mass on angular acceleration in different materials
  • Investigate real-world applications of angular acceleration in engineering
Physics students, mechanical engineers, and anyone interested in the principles of rotational dynamics and their applications in real-world scenarios.
j-e_c
A wooden door is closed by applying a perpendicular force to it. If the magnitude of the force is constant and takes 2 seconds for the door to close, how long would it take to close the door with the same amount of force, in the same manner, if the door was made of a material 4 times heavier than the wood? Assume the door is initially at rest and neglect friction.
-Angular acceleration is torque/moment of inertia
-[tex]\alpha[/tex]= [tex]\frac{N.m}{kg.m.m}[/tex] so for a constant force and length of door, the angular acceleration is inversely proportional to the mass.
-So, if the door is 4 times the mass, the acceleration is 4 times smaller.
-I then applied a constant acceleration equation: s=ut+[tex]\frac{1}{2}[/tex]a[tex]^{2}[/tex] to circular motion:
-[tex]\theta[/tex]=[tex]\frac{1}{2}[/tex][tex]\alpha[/tex]t[tex]^{2}[/tex]
-So, if r is a constant, then [tex]\alpha[/tex] is inversely proportional to t[tex]^{2}[/tex]
-Therefore, if you make [tex]\alpha[/tex] 4 times smaller, then t will double.
So, finally, t=4s.
Seems to make sense... is 4s the right answer?
I have no way of knowing. This question is from a university past paper for which there is no mark scheme. That's why I posted it here really.
  • · Replies 17 ·
