Determine Scalar Potential Function
The discussion revolves around finding the scalar potential function, φ, for a given vector field v = y²z³i + 2xyz³j + 3xy²z²k. Participants explore the implications of the relationship v = ∇φ, addressing whether additional constants or functions are necessary in the potential function and discussing different methods for deriving it.
  • One participant questions whether F, G, and H must be zero in their derivation of φ, or if a constant should be included, suggesting φ = y²z³x + C.
  • Another participant explains that if there are two potentials φ and φ₂ such that ∇φ = v and ∇φ₂ = v, then φ - φ₂ must be constant.
  • A participant expresses confusion about determining if multiple potentials exist based solely on the initial information provided.
  • One participant proposes a method involving starting with an unknown function φ(x,y,z) and integrating to find the potential function, concluding that any constant C works.
  • Another participant shares their experience with a different method taught in college, which involves finding partial derivatives individually and integrating them, but expresses frustration over its inadequacy for more complex problems.
  • Participants discuss the relationship between harmonic conjugates and potential functions, noting discrepancies in results when using different methods.
  • One participant suggests that the functions arctan(y/x) and -arctan(x/y) differ by a constant, indicating they have the same partial derivatives.
  • Another participant acknowledges the importance of careful application of methods during exams to avoid confusion.
Participants express differing views on the necessity of including constants in the potential function and the effectiveness of various methods for finding potential functions. The discussion remains unresolved regarding the best approach to take.
Some methods discussed may not be adequate for all types of problems, and participants highlight limitations in their approaches, particularly when dealing with more complex functions.
teeeeee
Hi,
I wonder if someone could help me.
I'm trying to find the potential function,[tex]\phi[/tex], of the field: v = y2z3i + 2xyz3j + 3xy2 z2k
So using v = [tex]\nabla\phi[/tex], I have found:
[tex]\frac{\partial \phi}{\partial x}[/tex] = y2z3x + F(y,z)
[tex]\frac{\partial \phi}{\partial y}[/tex] = y2z3x + G(x,z)
[tex]\frac{\partial \phi}{\partial z}[/tex] = y2z3x + H(x,y)
So my question is:
Does this mean that F,G and H are all zero... and therefore [tex]\phi[/tex] = y2z3x
or do I still need to include some constant, so that [tex]\phi[/tex] = y2z3x + C , for example.
Help will be much appreciated,
Thanks, teeeeee
Hi teeeeee! :smile:
(have a phi: φ and a curly d: ∂ and a del: ∇ :wink:)
If there are two solutions, φ and φ2, then ∇(φ - φ2) must be 0, so yes, φ - φ2 must be constant. :smile:
I don't understand what you mean..
So are F,G and H all zero? Or do I need to include a constant at the end? Or a function of all three variables at the end?
Thanks
If there are two different potentials, φ and φ2, such that ∇φ = v and ∇φ2 = v,
then ∇φ - ∇φ2= v - v = 0,
so ∇(φ - φ2) = 0,
so (φ - φ2) must be constant. :smile:
How do I determine if there are 2 different potentials..?
All the information I have is in my first post.
teeeeee said:
Hi,
Thanks, teeeeee
As others have pointed out, there isn't any the potential because adding a constant gives another potential for the same field.
But I would suggest a better way to come to the solution:
Start with an unknown function [itex]\phi(x,y,z)[/itex] that is to be your potential function. Then you must have
[tex]\phi_x = y^2z^3[/tex]
Integrating both sides of this with respect to x tells you
[tex]\phi(x,y,z) = xy^2z^3 + h(y,z)[/tex]
since the "constant" of integration can have y and z in it. Next check the partial with respect to y:
[tex]\phi_y = 2xyz^3 + h_y(y,z) = 2xyz^3[/tex]
This tells you that [itex]h_y(y,z) = 0[/itex] so h(y,z) = f(z), a pure function of z. So now we know:
[tex]\phi(x,y,z) = xy^2z^3 + f(z)[/tex]
Now check the partial with respect to z:
[tex]\phi_z = 3xy^2z^2 + f'(z) = 3xy^2z^2[/tex]
This says f'(z) = 0 so f(z) = C, a constant. This tells us
[tex]\phi(x,y,z) = xy^2z^3 + C[/tex]
This takes the guess work out of it and also tells you any C works. The simplest answer is when C = 0.
Hi everyone...I have been doing this kind of sums myself...but in college,we were taught a different method...they find out
[tex]\phi_x[/tex],[tex]\phi_y[/tex],[tex]\phi_z[/tex] individually,then integrate each..then we check for the common terms...when we collect all the common terms to get the final function.
This seems to be equivalent to the process described by LCKurtz,but if we apply a similar procedure (as taught in my college)to find out the harmonic conjugate of an analytic function,it doesn't work!
(What is puzzling me is,inspite of using a similar procedure for a similar situation,we don't get required results.)
Say,for example we have u=1/2(log(x^2+y^2))...we have to find its harmonic conjugate(i.e v)
...now,we get ux,uy (the partial derivatives)...and we have vx=-uy ...(eqn1)and vy=ux...(eqn 2)...so if we integrate each of the equations,and then compare,we don't get the correct value of v!
(The answer is v=tan inverse of (y/x), but if we integrate equation 1,we get tan inverse of (x/y)).
I'm sorry to hear that. That method, while it will work the easy ones, is not adequate for the more complex ones and can lead to misleading or wrong answers.
I think you get -arctan(x/y) don't you?
Hint: What happens if you differentiate arctan(x) + arctan(1/x)? What can you conclude?
well,you get 0...which means the function arctan(x) + arctan(1/x) is constant (value is pi by 2).
But then in the sum,we get v=arctan(y/x) -arctan(x/y) ...which can't be simplified to give a proper answer.
It means that arctan(y/x) and -arctan(x/y) differ by a constant so they have the same partial derivatives. One answer is as good as the other.
Oh... I get it! However,while working it out in the exam,I'd better be careful...perhaps if I follow the method that you originally mentioned,instead of integrating both equations,it might prevent the teacher getting confused,
  • · Replies 16 ·
  • · Replies 19 ·
