Buy Neodymium Magnets for Inducing Current on a Budget
  • Context: Undergrad
  • Thread starter Thread starter bigmack
    Magnetic
This discussion centers on the use of neodymium magnets, specifically N50 grade, for inducing current in a budget-conscious project. The user compares two magnets of different sizes, noting that the larger 2"X2"X1" magnet has a pull force of 250 lbs, while a smaller eighth-inch cube has a pull force of 2.5 lbs, despite both having the same gauss rating of 14,500. The user seeks clarification on whether the size affects current generation and inquires about the relationship between the number of magnets and their combined pull force. A suggestion is made to use calculators from kjmagnetics.com for precise pull force calculations.
  • Understanding of neodymium magnets and their grades, specifically N50.
  • Knowledge of magnetic pull force and its dependence on size.
  • Familiarity with electromagnetic induction principles.
  • Basic mathematical skills for calculating magnetic forces and current generation.
  • Research the principles of electromagnetic induction and how magnet size affects current generation.
  • Learn about the formulas for calculating induced current using Faraday's Law of Induction.
  • Explore online calculators for magnetic pull force, such as those available at kjmagnetics.com.
  • Investigate the effects of combining multiple magnets on overall magnetic strength and pull force.
This discussion is beneficial for hobbyists, engineers, and students involved in projects that utilize neodymium magnets for electromagnetic applications, particularly those working with budget constraints.
bigmack
Ok so I'm working on a project involving magnets and inducing current. Thing is that I'm on a budget and need to make sure that I buy the right things.
For my project I'm going to need neodymium magnets. Using the magnets I'm going to induce current.
I found a website selling magnets. It has different types of N50 grade magnets. What I want to know is, if all the magnets are N50 grade, then how come they have different pull forces. I think it might have to do with the sizes... because one of the magnets is 2"X2"X1" and it has an approximate pull force of 250 lbs, an other magnet is a cube with a side being an eighth of an inch, it has a pull force of 2.5 lbs. Both these magnets are N50 and are 14,500 gauss.
I'm going to conclude that the bigger the magnet, the stronger pulling force it has.
But since both magnets have the same gauss, does it mean that both magnets would generate the same amount of current? Would one of the magnets produce more current than the other?
Oh, and can someone please give me an equation for working out the current that is generated. Using a coil to cut the fields, and a single wire, please.
Oh and yeah, if I got 10 of the smaller magnets, and joined them together, then would their pull force increase, would it increase proportionally, so that if I joined an infinite number of the small magnets, the pulling forcec would increase infinitely in proportion?
Try this on-line pull calculator
http://www.dextermag.com/Calculation.aspx?mode=input&id=ForceCalcCylinder
Bob S
ok I can't help you with much more than the last part...if you go to kjmagnetics.com they have a pull and a push force calculator and you can chose the type of magnet and the size and press enter and it will calculate the pull or push force for you. Hope this helps you!
  • · Replies 59 ·
  • · Replies 17 ·
