Thread Closed
Why do we take the "probability of an event" ratio as favorable / possible outcome
Share Thread Thread Tools
Jan6-10, 03:37 PM   #1
If A is an event, then probability that A will occur is given by
P(A)= no. of favorable outcomes / total no. of possible outcomes
Is this just a definition, or is there some special significance in taking the number of favorable outcomes as the numerator and total no. of possible outcomes as the denominator? Is it because since the numerator will always be less than the denominator, it will be easier to work with the ratio?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jan6-10, 03:58 PM   #2
Definitions.
Given a sample space, the probability of the entire sample space is 1, the probability of any element in the sample space is [0,1].
Jan6-10, 04:28 PM   #3
Quote by farful View Post
And how does this relate to the numerator being the number of favorable outcomes and the denominator being the total number of possible outcomes?
Jan6-10, 10:47 PM   #4
Quote by Juwane View Post
"Favorable" is a judgment within some context. A probability simply relates the number of designated outcomes to all possible outcomes. The designated outcomes could be favorable, unfavorable or neutral depending on your point of view.
Jan7-10, 08:46 AM   #5
My question is that why the favorable outcomes is in the numerator and total possible outcomes is in the denominator? Why not vice versa? Is it just a definition or does it have a significance?
Jan7-10, 09:26 AM   #6
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi Juwane!
Because for two independent events, you want both P(A + B) = P(A) + P(B), and P(AB) = P(A)P(B), and favourable/possible is the only way of doing that.
Jan7-10, 11:22 AM   #7
I still don't understand. I like to understand through an example:
A coin is tossed. The probability that we will get a head is 1 over 2.
Another example:
A die is cast. The probability that we will get a 3 is 1 over 6.
Now my question is why, in the first example, it is 1 over 2 and not 2 over 1; and why in the second example it is 1 over 6 and not 6 over 1?
Jan7-10, 12:00 PM   #8
Recognitions:
… why in the second example it is 1 over 6 and not 6 over 1?
You could define it as 6 over 1, but then the probability of a 4 would be 6 over 1 also. and the probability of a 4 or a 3 would be 6 over 2, = 3 over 1.
And the probability of throwing the dice twice and getting a 4 first time and a 3 second time would be 36 over 1.
Jan7-10, 12:09 PM   #9
Quote by tiny-tim View Post
So it's just the definition, right? Because it makes sense to say that the probability of getting a head in a coin throw is half, so it's 1/2, right?
Jan7-10, 12:19 PM   #10
Recognitions:
Right.
Mathematicians can define anything they like.
But a definition, even if perfectly valid, is only useful, if it successfully models the real world.
Jan7-10, 12:26 PM   #11
Well, you could take instead favorable outcomes / unfavorable outcomes and call it "odds".
So odds of 10 : 1 mean two probabilities of 10/11 and 1/11.
Jan9-10, 11:53 AM   #12
Recognitions:
By Gee!, by Gosh! It was Laplace who DEFINED the probability of an event as the favorible outcomes divided by the total outcomes!! It is the basic definition.
Feb14-10, 02:39 PM   #13
Example: What is the probability that heads will fall on one throw of a coin? From theoretical probability, P(heads)=1/2. This means that 1/2 or 50% of your tosses of a coin should land on heads, theoretically. The numerator must be the favorable outcomes and the denominator must be the total possible outcomes. This ratio is 1 to 2 or 1:2, meaning, 1 out of every 2 tosses of the coin should result in heads. If you had possible outcomes in the numerator the ratio would be 2 : 1 , which would mean that you could toss 2 heads in 1 throw with one die. Impossible.
Feb15-10, 01:03 PM   #14
Quote by bcramton View Post
2 possible outcomes doesn't mean they are both heads.
Feb15-10, 01:13 PM   #15
Now my question is why... is it 1 over 6 and not 6 over 1?
1] What would it accomplish to have it defined as 6/1? Are there any ways this would be better?
2] There are a number of very useful reasons for defining it as 1/6. For example, you can add up all the possbilities and arrive at 1 again: 1/6+1/6+1/6+1/6+1/6+1/6 = 1. i.e. all individual possibilities add up to the total possible outcomes.
How would you do this if it were represented as 6/1?
Thread Closed
Thread Tools
Similar Threads for: Why do we take the "probability of an event" ratio as favorable / possible outcome
Thread Forum Replies
Bigbang Bigcrunch "Singular" event? Special & General Relativity 0
Highest "income to working-hour" ratio Academic Guidance 6
Windows Vista: "System Event Notification Service"? Computers 0
Attempts to make the Born rule "emerge" explicitly from outcome counting Quantum Physics 4
What is meant by "signal-to-noise ratio?" General Engineering 15
