Magnetism's Effects on Watches: Explained
  • Context: High School
  • Thread starter Thread starter Rudra Roy
    Magnetism
The discussion centers on the effects of magnetism on different types of watches, exploring why some watches stop functioning when exposed to magnetic fields. Participants examine various watch mechanisms, including mechanical and quartz watches, and their susceptibility to magnetic interference.
  • One participant questions why watches stop when near a magnet, seeking an explanation of the underlying mechanisms.
  • Another participant notes that the type of watch (mechanical vs. digital) influences the effect of magnetism, suggesting that mechanical parts may become magnetized, impacting performance.
  • A participant shares personal experiments with three types of watches, observing that the spring-run watch is unaffected by magnets, while two battery-operated watches are affected, raising questions about the Earth's magnetic field's influence on watch components.
  • Concerns are raised about quartz watches being affected by magnets, with one participant asserting that quartz crystals are resistant to magnetic fields, while mechanical watches can experience inaccuracies due to magnetization of parts.
  • Another participant mentions that decent mechanical watches often include magnetic shielding to protect against magnetic fields, but acknowledges that magnetization can lead to significant timing issues, which can be corrected by a watchmaker.
  • A challenge is posed regarding the assertion that quartz watches should not be affected by magnets, with a participant claiming to have conducted tests that contradict this view.
Participants express differing views on the susceptibility of quartz watches to magnetic fields, with no consensus reached on the extent of magnetism's effects on various watch types.
Participants reference personal experiences and tests, but the discussion lacks definitive conclusions regarding the mechanisms at play and the varying impacts of magnetism on different watch types.
Rudra Roy
Can anyone explain to me why does a watch stop when it is brought near a magnet?I want to know how does the magnet affect the watch.
The answer is depends on what "type" of watch. Digital/no moving parts? Mechanical?
In a mechanical watch, you are influencing the interaction of the ferrous mechanical parts. Some could become magnetized, permenantly affecting the watch's performance.
I have tried out with three types of watches.One of them is the spring-run watch of the olden days.Another one is the modern wrist watch, run on battery.And the 3rd one is also a modern wrist watch working on battery but the hands of the watch and the dial are made of plastic(none is digital).The magnet has no effect on the spring-run watch but it strongly effects the other two watches.So, we can see that a magnetic field affects the 2nd and 3rd watches.We know that the Earth has a magnetic field..So my question is that why Earth's magnetic field does not affect the parts of the watches, when it can affect a magnetic needle(since the parts of a watch are very small, I have compared their strength with that of a needle)?
I would be highly suspicious of a quartz watch being affected by a magnet. They do not have any mechanical motion outside of any physical hands and such. The timing mechanism, the quartz crystal, is fairly resistant to magnetic fields from what I know. A mechanical watch is affected because as previously stated the magnetization of the parts will create additional forces on the gears and such which will result in inaccurate running. A watch has to be very very precise to keep decent precision throughout the day, some mechanical watches easily run at around 20,000 beats per hour. That's 480,000 beats a day. If the watch gains say 4 seconds a day, then that means that each beat is only off on something of the order of a millionth of a beat. So even small imbalances can add up over time.
However, fortunately, any decent mechanical watch will have magnetic shielding in the form of a thick iron plate that sits behind the watch mechanism (though this is not there for watches with skeleton backs so that you can observe the mechanism). This help keep the watch from being affected by a magnetic field. If a watch does become magnetized, I have heard that the affects are rather pronounced, something on the order of minutes for each hour. A watchmaker can demagnetize the watch and correct the problem.
U are saying that the quartz watch should not be affected by a magnet.But then how does the magnet affect the watch?I have tested it several times.U can also test it.
  • · Replies 16 ·
  • · Replies 22 ·
