Need help with where i can get a switch.
  • Thread starter Thread starter mjb811
    Switch
The discussion revolves around finding a suitable on/off toggle switch for a bilge pump on a jet ski, specifically addressing the challenges posed by the thickness of the mounting panel and the need for waterproofing. Participants explore various sources and alternatives for acquiring the switch.
  • Exploratory, Technical explanation, Debate/contested
  • One participant specifies the need for a toggle switch with a 2-inch long threaded back part and a waterproof cover, noting unsuccessful searches at several electronics suppliers.
  • Another participant suggests that a shorter toggle switch could be used if longer wires are run, and recommends checking with the jet ski manufacturer or an auto parts store.
  • A different participant counters that a regular toggle switch would not fit due to the inability to secure the backing nut in the thick panel, emphasizing that the bilge system is aftermarket.
  • One participant asks for details about the jet ski model and the bilge pump manufacturer, suggesting that contacting the pump manufacturer for replacement parts might be beneficial.
  • Another participant recommends checking Fry's or Tanner Electronics for potential options, as well as Mauser.
  • One participant advises trying a marine supply store for push-pull switches, noting that thick panels are a common issue in boats.
Participants express differing opinions on the feasibility of using alternative switch types and sources, indicating that no consensus has been reached regarding the best solution for the switch issue.
Participants have not provided specific identifying numbers for the switch or detailed information about the jet ski model, which may limit the effectiveness of their suggestions.
Individuals seeking to replace or install switches in marine applications, particularly those dealing with thick mounting panels or aftermarket systems.
mjb811
i need an on/off toggle switch for my bilge bump on my jet ski. But, the mounting panel is about 2 inches thick where the fiberglass is. the stem could be short but the threaded (back part) needs to be about 2 inches long in order to fit. I also need a platic or waterproof cover for it to keep it water tight. I have look on MCM electronics, Radio shaft, and switches unlimited but no luck. anyone know where i can find one? thanks
Can you not just use any ole toggle swith? I mean, could you not use something shorter, and just run longer wires to make up the difference?
Also, have you checked with the manufacturer of your Jet ski? You might try taking the old switch to an auto parts store.
a regular toggle switch will not work because there will be no way to get the connection part in the hole and tighten the backing nut. it is an aftermarket bilge system so the jet ski manufacturer won't have any info on it.
What kind of jet ski is it?
Who makes the bilge pump?
(have you checked with the pump manufacturer to ask for replacement parts?)
Any identifying numbers on the switch?
If so, what are they?
Fry's, possibly. There's a place here in the DFW area called Tanner Electronics that carries a wide assortment. Perhaps Mauser.
Try a marine supply. They will have push-pull switches, similar to the old auto starter switches, that have long shanks. That is a very common problem in boats, the panels are very thick.
  • · Replies 30 ·
