Möbius transformations and SO(3)
  • Context: Graduate
  • Thread starter Thread starter csopi
    So(3) Transformations
This discussion focuses on establishing a bijection between the special orthogonal group SO(3) and fractional linear transformations defined by the formula \(\varphi_{z,w}(u) = \frac{zu+w}{-\bar wu+\bar z}\), where \(u \in \mathbb{C} \cup \{\infty\}\) and \(z, w \in \mathbb{C}\). Key insights include that fractional linear transformations can be viewed as projections of linear transformations in a two-dimensional complex vector space, specifically those that preserve the unit sphere. The relationship between SO(3) and these transformations is highlighted, particularly noting that SO(3) can be represented as the unit sphere in complex 2-space modulo multiplication by -1.
  • Understanding of SO(3) and its geometric properties
  • Familiarity with fractional linear transformations
  • Knowledge of complex vector spaces and linear transformations
  • Basic concepts of the Riemann sphere
  • Study the properties of fractional linear transformations in detail
  • Explore the geometric interpretation of SO(3) in relation to complex vector spaces
  • Investigate the implications of linear transformations preserving the unit sphere
  • Learn about the Riemann sphere and its applications in complex analysis
Mathematicians, physicists, and students studying geometry, particularly those interested in the relationships between group theory, complex analysis, and transformations in higher dimensions.
csopi
Hi,
I was given the following problem, and i couldn't solve it yet:
Give a bijection between the elements of SO(3) and the fractional linear transformations of the form
[tex]\varphi_{z,w}\,(u)=\frac{zu+w}{-\bar wu+\bar z}[/tex], where [tex]u\in \mathbb C\cup \{\infty\};\, z,w\in \mathbb C[/tex].
Any ideas would be highly appreciated.
csopi said:
Hi,
Here are a few things to think about.
- A fractional linear transformation is the projection of a linear transformation of a 2 dimensional complex vector space. The linear map with matrix
a b
c d
projects to the fractional linear transformation az + b/ cz + d.
- two linear transformations of the complex 2 space that differ by a complex constant project to the same fractional linear transformation.
- Some linear transformations carry the unit sphere in complex 2 space i.e. the vectors (a,b) such that |a|^2 + |b|^2 = 1 , into itself. If two of these differ by a sign they project to the same fractional linear transformation
- SO(3) is the same as the unit sphere in complex 2 space modulo multiplication by -1. In other words, SO(3) may be thought of as those fractional linear transformations that are projections of linear maps of C^2 that preserve the unit sphere.
- if w = 0 then the fractional linear transformation just rotates the plane around the origin. As a map of the Riemann sphere into itself is is just a rotation with infinity and zero as the two fixed poles.
The general fractional linear transformation has two fixed points that are complex conjugates of each other.
  • · Replies 39 ·
