Work done by gravity on a object on an inclined plane
by hyuen9195
Tags: frction, gravity, incline plane, work
hyuen9195
hyuen9195 is offline
#1
Jan9-10, 03:34 PM
P: 5
A 11.0 kg crate is pulled up a rough incline with an initial speed of 1.3 m/s. The pulling
force is 121.0 N parallel to the incline, which makes an angle of 12.6◦ with the horizontal.
The coefficient of kinetic friction is 0.31 and the crate is pulled a distance of 8.0 m.
The acceleration of gravity is 9.81 m/s^2 .
2. Relevant equations
a) Find the work done by Earth’s gravity
on the crate. Answer in units of J.
3. The attempt at a solution
Fnormal=m*g*costheta
Fnormal=105.3111778N
Fnormal* coefficient of friction=Ffriction
Ffriction=32.64646511N
Fapplied-Ffriction=Fnet
Fnet=88.35353489N
Work=N*m
Work=706.8282791N*m
-(Work*sin12.6)=W done by gravity
Work done by gravity is 154.1898119N*m
I think I did it right, but the computer marked me wrong. Can anyone explained this?
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
pgardn
pgardn is offline
#2
Jan9-10, 04:00 PM
P: 621
Quote Quote by hyuen9195 View Post
Fnet=88.35353489N
Work=N*m
Work=706.8282791N*m
What did you calculate the force of gravity is that is parallel to the displacement up the plane?
hyuen9195
#3
Jan9-10, 04:24 PM
P: 5
The displacement is parallel to the plane. If thats what you are asking
vela
vela is offline
#4
Jan9-10, 05:17 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 11,521
Your last step is incorrect. I'm not sure what you're trying to do there. Can you explain your thinking?
hyuen9195
#5
Jan9-10, 05:19 PM
P: 5
a) Find the work done by Earth’s gravity on the crate. Answer in units of J.
I think you have to find the work done on the block parallel to the plane, then find the y component of the work
pgardn
pgardn is offline
#6
Jan9-10, 05:42 PM
P: 621
Work is Force x displacement said very simply.
So the displacement is 8 m up and parallel the plane. All you need is the force due to gravity that is also parallel to the plane, thus also parallel to the displacement. What is the force due to gravity that is parallel to the displacement?And then, is it in the same direction as the displacement (+) work, or is it in the opposite direction as the displacement, (-) work.
vela
vela is offline
#7
Jan9-10, 09:18 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 11,521
Work is a scalar quantity, not a vector. It doesn't have a y-component. You'll need a different approach. Hint: The work done by gravity is the work done by only the force of gravity. You don't need to consider any of the other forces to calculate it.
When I said earlier that your steps were correct, I didn't mean to imply that they would all be necessarily useful in trying to calculate the work done by gravity, just that you didn't make any physics mistakes in deriving them.
hyuen9195
#8
Jan10-10, 04:11 PM
P: 5
Weight*Distance sine theta=Work done by the gravity
b) Find the work done by the force of friction on the crate.
Weight*Distance cos theta*coefficient=Work done by the force of gravity
c) Find the work done by the puller on the crate.
Applied Force *Distance=Work done by the puller on the crate
d) Find the change in kinetic energy of the crate.
Answer to c-(Answer to b+Answer to c)=The change in kinetic energy of the crate
e) Find the speed of the crate after it is pulled 8.0 m.
The square root of [((2*Answer to d/Mass)+Vi^2)]
I finally figured c out and ask my classmate for the others
http://answers.yahoo.com/question/in...2140953AATtl7k
vela
vela is offline
#9
Jan10-10, 04:21 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 11,521
You should have negative answers for (a) and (b).
hyuen9195
#10
Jun3-10, 04:08 PM
P: 5
For part d, it's Answer to c-(Answer to b+Answer to a)=The change in kinetic energy of the crate
Rayquesto
Rayquesto is offline
#11
Feb28-11, 08:38 PM
P: 317
I believe that the amount of work done by gravity is equal to the potential gravitational energy. Therefor, if you find the height as it goes up a 8 meter incline, then you can also find the work using mgh (meters times gravitational acceleration times height). so I think the answer is 188 J, since sin12.5=height/8 where height is 1.745 meters, g=9.81m/s^2, and 11kg=mass. multiply them and you get the amount of joules it applied which should be 188 J. Well, then again if we consider the chnage in potential energy we can safely assume that the initial potential energy is 0. so, 188 j still holds true.
Register to reply
Related Discussions
distance covered by a moving object versus friction in an inclined plane Introductory Physics Homework 1
work on an inclined plane Introductory Physics Homework 1
Motion of 2 object on an inclined plane Introductory Physics Homework 1
[SOLVED] Object Traveling Up an Inclined Plane Introductory Physics Homework 6
Object being pushed up an inclined plane Introductory Physics Homework 4
