| Thread Closed |
solar boat having solar panel power problem |
Share Thread | Thread Tools |
| Jan10-10, 01:39 AM | #1 |
i have made solar boat having 4V 400mA rating solar panel. when i put under sunlight there is no problem
but i have to run it under helogen light so when i put it undet bulb then it gives me only 200mA current at 25 cm distance i can't decrease distance i m using 1381 solar engine using 5.5V/1F gold capacitor so problem is my motor cannot get enough initial torque to get start and i cannot observe charging and discharging of capacitor now what should i do? |
| Jan10-10, 02:32 AM | #2 |
Welcome to PF, Ashish.
I suspect that it's because the halogen light's restricted frequency range covers only half of what your cells are designed to work with. Wait for someone else to answer before acting, but my initial suggestions would be to either replace the halogen source with full-spectrum fluorescents or switch to cells that are attuned to the specific output of halogens. Those would probably be either too expensive or physically/practically not achievable. Other than that, all that I can think of is to double the number of cells that you use, or find some way to collect and concentrate the available light to double your watts/metre^2. |
| Jan10-10, 02:25 PM | #3 |
Solar cells are tricky since they are rarely exposed to the conditions at which they are rated. |
| Jan10-10, 03:25 PM | #4 |
solar boat having solar panel power problemI would then find the suffix on your 1381. If the voltage across the capacitor does not reach the rated trigger voltage of the 1381 device, your boat will never run. ps. everything I know about the 1381 solar engine I've learned in the last 10 minutes. |
| Jan10-10, 11:58 PM | #5 |
no i am using 1381I(2.7V trigger voltage)
and bullet high torque motor(150-160 mA at no load condition ,2000-3000 rpm ) but boat is working not like under solar light i cannot change my distance and halogen flourescent tube? should i change motor or what if i connect 4V 200mA and 0.5V 750mA two solar panel in siries or parallel? ad one another thing i have to run boat in tunnel having 300 cm lengh so what should i do ? i cannot observe chrging and discharging of capacitor! |
| Jan11-10, 01:04 AM | #6 |
| Jan11-10, 06:39 AM | #7 |
no u could not understand properly i have multimeter.what indicate voltage across capacitor. and what should voltage across capacitor?
| Jan11-10, 07:53 PM | #8 |
| Jan12-10, 10:19 AM | #9 |
no i told u my boat is running
| Jan12-10, 10:25 AM | #10 |
| Jan12-10, 12:09 PM | #11 |
ya can change simple 3V 2000-3000 RPM instead of bullet high torque motor
or should i change i circuit to get more power at a time? |
| Jan12-10, 12:18 PM | #12 |
A capacitor is not a good storage medium for the energy from a solar cell. The stored charge is only CV and the volts are very low. I suggest that the starting current for the motor is enough to discharge the capacitor so much that it never gets going.
The only way around that would be to charge several capacitors in parallel then connect them in series to get more volts. That's why they use rechargeable batteries - they have a nearly constant voltage / charge characteristic! Also, have you observed the voltage on the capacitor with the solar cell charging it and without the motor connected? Perhaps it is never actually charging to the required voltage. You could wait for the C to charge up then connect it. I have also been very disappointed by solar cell performance under tungsten light. They go far better when there's a lot of blue and UV! |
| Jan13-10, 01:21 AM | #13 |
hi can anyone tell me where i can get solar panel(having higher current rating)?
| Jan13-10, 10:26 AM | #14 |
5 watts for $40 10 watts for $108 10,000 watts for $36,000, but I think you'll need a bigger boat. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: solar boat having solar panel power problem
| 6V 300mA solar panel or 4v 430mA panel | Mechanical Engineering | 5 | ||
| solar panel | Electrical Engineering | 0 | ||
| solar panel | Quantum Physics | 2 | ||
| 45 W solar panel | Engineering Systems & Design | 1 | ||
| Solar Panel question | Electrical Engineering | 6 | ||
