Box sliding down frictionless incline
The problem involves a box sliding down a frictionless incline, initially at rest and then with an initial speed. The goal is to determine the final speed of the box at the bottom of the ramp when it starts with an initial speed of 3 m/s.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of conservation of energy principles and the relationship between potential and kinetic energy. There are questions regarding the meaning of variables in equations and attempts to clarify the setup of the problem.
Several participants have suggested using conservation of energy to approach the problem. There is ongoing clarification of the equations involved, and some participants are exploring different methods to arrive at the final speed.
Participants note the absence of certain information, such as the length of the ramp and the mass of the box, which may affect their approaches. There is also a recognition of potential confusion in earlier attempts to solve the problem.
pewpew23
A box initially at rest at the top of a frictionless ramp is allowed to slide to the bottom. At the bottom its speed is 4 m/s. Next, the box is again slid down the ramp, but this time it does not start from rest. It has an initial speed of 3 m/s at the top. How fast is it going when it gets to the bottom?
No idea...
Since the length of the ramp, mass of the block, nor the time it takes to get from the top of the ramp to the bottom is given... I don't know where to start with this one.
EDIT: What I had done was wrong :).
Matterwave is correct, just use conservation of energy.
I'm not sure I understand your equation...
vf meaning velocity and ?
vi is initial velocity, correct?
Yes, I'm just using a subscript to denote the initial and final states of the velocity.
Perhaps Jegues' method is simpler, but I would approach this in terms of energy conservation. Potential energy at top = kinetic energy at bottom. The m's will cancel out.
so a=(vf-vi)/t
a=4/t
a=(vf-3)/t
set them equal to each other
4/t = vf-3/t
t's cancel out and we get 4= vf-3
and vf=7 :)
Bump, I edited my post above. As Matterwave suggested conservation of energy is what you're looking for.
EDIT:
so a=(vf-vi)/t
a=4/t
a=(vf-3)/t
4/t = vf-3/t
and vf=7 :)
This is what I had initially suggested. It is wrong. Use conservation of energy, sorry in advance for any confusion.
KE= 1/2mv^2
GPE= mgh
and that would give us h= .81716
but how would I use that solve for vf is vi=3?
You generated the height using the first case good!
Now for second case, in the intial state what types of energy are there? In the final state what types of energy are there?
At the top of the ramp, all energy is in Gravitational Potential (mgh) and KE.
and at the bottom there is only KE.
1/2vi^2 + gh = 1/2vf^2
12.499 = 1/2vf^2
and vf = 4.9
Looks correct to me!
