Finding Electric Field from Potential: Understanding Why and How
  • Context: Undergrad
  • Thread starter Thread starter Identity
    Field Potential
The discussion revolves around understanding the relationship between electric potential and electric field, specifically how to derive the electric field from the potential and why a zero potential does not imply a zero electric field. The scope includes theoretical reasoning and mathematical relationships in electrostatics.
  • One participant notes that they found the potential at a point to be zero but questions why the electric field is not zero, prompting an exploration of the relationship between potential and electric field.
  • Another participant explains that potential is arbitrary and emphasizes that the electric field is derived from the gradient of the potential, indicating that a zero potential does not necessarily mean a zero electric field.
  • There is an analogy made comparing the relationship between potential and electric field to a function and its derivative, suggesting that knowing the potential at a single point does not provide enough information to determine the slope (electric field) at that point.
  • A further analogy is presented, clarifying that to find the slope at a point, one needs values of the function at neighboring points or a general formula for the function, which relates to finding the electric field from the potential.
Participants appear to agree on the concept that potential can be zero while the electric field is not, but there is no consensus on the implications of this relationship or the best approach to derive the electric field from the potential.
The discussion includes assumptions about the nature of electric potential and field, such as the arbitrary nature of potential and the requirement for a general formula to derive the electric field. There are also unresolved nuances regarding the implications of knowing potential at discrete points versus a continuous function.
Identity
Say you have a charge distribution in the picture, and you want to find the potential THEN the electric field at P, using [tex]E = -\nabla V[/tex]
I found the potential to be 0, and yet the field isn't. Why is this?
And how would we get the actual field from the voltage?
Potential is arbitrary. It is easy to see, from the relationship that the electric field is the gradient of the potential, that we can give the potential any DC offset and not affect the resulting electric field. What is of true importance for us is the potential difference.
For point charges, it is often simple to set the potential at infinityto be zero. Under such an assumptions, then yes, the potential at point P, or in fact at any point along the z-axis (the dotted line in the picture) the potential will be zero. However, the electric field is related to the gradient of the potential. So just because a function evaluates to zero at a point does not mean that the derivative of the function evaluates to zero at that point as well.
If you were to work out the gradient of the general expression for the potential at any point, then you would find that if you solved for the field at point P it would be non-zero.
Oh, ok, so by analogy, if you find the potential anywhere, it's like finding
[tex]f(x)[/tex], from which you can find [tex]f'(x)[/tex]
However if you find the potential only at 1 point or a set of points, it's like finding
[tex]f(x_0)[/tex], and from that [tex]\frac{d}{dx}f(x_0) = 0[/tex] since it's a constant?
Is that kinda right?
thanks
Allow me to make an analogy... you know that for a function of a single variable, the derivative at a point is the slope of a graph of the function at that point, right? What you're saying is that if you find the value of a function at only one point, then the slope has to be zero at that point. Does that make sense? :smile:
In order to find the slope at a point, you need to know the values of the function not only at the point in question, but also at neighboring points. Either you know an explicit value at some particular nearby point, in which case you calculate the slope approximately as [itex]\Delta y / \Delta x[/itex]; or you know a formula for the function, in which case you find the derivative of the formula (which gives you the slope at all points) and evaluate it at the point in question.
In this case you have to find a general formula for the potential at all points, and then find the negative gradient of that formula (which gives you the field at all points) and evaluate it at the point in question.
Ah ok thanks jtbell and Born2bwire
  • · Replies 22 ·
  • · Replies 21 ·
