The speed of sound of the inflaton field
The speed of sound of the inflaton field is defined using the equation c_s^2 = ∂_X P / ∂_X ρ, where X = (1/2) g^{ab} ∂_a φ ∂_b φ. For a canonical scalar field, the pressure P and energy density ρ yield c_s^2 = 1. However, variations in P and ρ can lead to conflicting interpretations of c_s^2, with one method yielding c_s^2 = -1 and another yielding c_s^2 = 1. The distinction between adiabatic sound speed and effective sound speed is crucial, as the effective sound speed is defined as 𝜏_s^2 = ∂_X P / ∂_X ρ, which differs from the adiabatic sound speed derived from thermodynamic perspectives.
  • Understanding of canonical scalar fields in cosmology
  • Familiarity with thermodynamic principles in relation to pressure and density
  • Knowledge of perturbation theory in field equations
  • Proficiency in calculus, particularly partial derivatives
  • Study the Klein-Gordon equation for scalar field perturbations
  • Explore the differences between adiabatic sound speed and effective sound speed
  • Investigate the implications of varying definitions of sound speed in cosmological literature
  • Learn about the role of scalar fields in inflationary cosmology
Cosmologists, theoretical physicists, and researchers studying inflationary models and scalar field dynamics will benefit from this discussion.
chronnox
I've been reading about inflation and i encountered that one can always define the sound's speed as
[tex]c_s^2 \equiv \frac{\partial_X P}{\partial_X \rho}[/tex]
where [tex]X \equiv \frac{1}{2} g^{ab} \partial_a \phi \partial_b \phi[/tex]. In the case of a canonical scalar field [tex]P=X-V[/tex] and [tex]\rho=X+V[/tex], so [tex]c_s^2=1[/tex]. That is what is obtained by definition. But i can always consider [tex]P[/tex] and [tex]\rho[/tex] as a function of [tex]P=(X,\phi)[/tex] and [tex]\rho=(X,\phi)[/tex] so
[tex]P+\rho=2 X[/tex] and
[tex]\rho-P= 2 V[/tex]
taking variations of these last to equations i obtain
[tex]\delta P = - \delta \rho + 2 \delta X[/tex] (1) and
[tex]\delta P = \delta \rho - 2 \partial_\phi V \delta \phi[/tex] (2)
Recalling that in general [tex]P=(\rho,S)[/tex] then [tex]\delta P = c_s^2 \delta \rho + \tau \delta S[/tex]. Thus if i read the coefficient of [tex]\delta \rho[/tex] of eq. (1) one obtains that [tex]c_s^2 = -1[/tex] and [tex]\tau \delta S = 2 \delta X[/tex], but if i read the coefficient of eq. (2) one obtains [tex]c_s^2 = 1[/tex] and [tex]\tau \delta S = - 2 \partial_\phi V \delta \phi[/tex], according to the definition the correct reading would be the one done by (2) but is there another explanation of why reading the coefficient [tex]c_s^2[/tex] from (2) is the correct way, or is there a motivation for the first definition for [tex]c_s^2[/tex]?
Space news on Phys.org
The problem is that the literature often uses [itex]c_{\rm{s}}^2[/itex] to mean two different things, sometimes simultaneously. Looking at things from a thermodynamic perspective, one can write [itex]P=P(\rho,S)[/itex], and then perturb to give
[tex]\delta P=\frac{\partial P}{\partial\rho}\delta \rho +\tau \delta S[/tex]
where [itex]\frac{\partial P}{\partial\rho}[/itex] is then identified as the adiabatic sound speed-- i.e. the speed with which perturbations travel through the background.
Now, for a scalar field we can parametrise as [itex]P=P(X,\phi)[/itex]. Then, the adiabatic sound speed can be written as
[tex]c_{\rm{s}}^2=\frac{\partial P}{\partial\rho}=\frac{\partial_X P +\partial_\phi P}{\partial_X\rho+\partial_\phi\rho}[/tex]. By writing things like this, it should be apparent that this is not the same as the first expression you quote. It turns out that, for a scalar field, the speed of propagation is not the adiabatic sound speed, but in fact a different speed (say, the "effective sound speed"), which is defined as
[tex]\tilde{c_{\rm{s}}}^2=\frac{\partial_X P}{\partial_X\rho}[/tex]. If you like, you can show this by calculating the Klein-Gordon equation for the perturbation of the field and looking at the term in front of the spatial derivative.
  • · Replies 0 ·
  • · Replies 0 ·
