What displaces more water- Mass or Volume?
by Realityguy
Tags: displaces, mass, volume, water
Realityguy
Realityguy is offline
#1
Jan12-10, 06:23 PM
P: 3
What will displace more water- an object with greater mass, or greater volume?
For instance, if you have a glass of water and you drop an object in that is heavy (mass), but relatively small in size versus dropping an item that is much larger in size (volume), but not nearly as heavy, which item would displace more?
The second part of the question.
Assume you had two items of the same size (volume), but two different weights or mass.
Would the displacement be the same based on volume, or greater based on mass?
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
pgardn
pgardn is offline
#2
Jan12-10, 06:30 PM
P: 621
Quote Quote by Realityguy View Post
Are we automatically assuming that the objects are denser than water(ie sink), or do we need to "hold" them under, like we would styrofoam?
If we hold them under or they sink this is pretty straight forward...
pgardn
pgardn is offline
#3
Jan12-10, 06:34 PM
P: 621
If the objects sink or we can "hold" them under maybe think of it this way...
If we filled water up to the top of a glass and then put a small cube of a very dense metal that weighed more or had a greater mass than all the water in the glass, would all the water jump out? Or only an amount equal to the size (read as volume) of the cube?
Register to reply
Related Discussions
What does mass, volume and density of displaced water mean? Introductory Physics Homework 4
An ice cube floating in water, what is the volume of the part under water? Introductory Physics Homework 8
Volume of water displaced...? Advanced Physics Homework 5
Is volume displaced by an item in water = volume of item * specific gravity of item? Introductory Physics Homework 7
homework help! Volume in water Introductory Physics Homework 9
