Thread Closed
A Compound Pendulum's Period
Share Thread Thread Tools
Jan12-10, 06:46 PM   #1
Consider a light rod of negligible mass and length "L" pivoted on a frictionless horizontal bearing at a point "O." Attached to the end of the rod is a mass "m." Also, a second mass "M" of equal size (i.e., m=M) is attached to the rod (0.2L from the lower end). What is the period of this pendulum in the small angle approximation?
2. Relevant equations
T=2pi(I/Hgm)^0.5
where H=the length from the center of mass to the point of rotation
rcm=(r1m+r2M)/(m+M)
Icm=m(L1)^2+M(L2)^2
I=Icm+m(d)^2
3. The attempt at a solution
rcm=(r1m+r2M)/(m+M)
rcm=[(L+0.8L)m)]/2m
rcm=0.9L (from the point of rotation)
Icm=mL^2+mL^2
Icm=m[(0.1L)^2+(-0.1L)^2]
Icm=0.02mL^2
I=Icm+md^2
I=0.02mL^2+m(0.9L)^2
I=0.83mL^2
T=2pi(I/Hgm)^0.5
T=2pi(0.83mL2/0.9Lgm)^0.5
T=2pi(83L/90g)^0.5
I'm really unsure as to what I'm doing wrong so it'd be great if someone could point out what I'm doing wrong--perhaps I've mistaken what one of the variable is supposed to represent? Thanks!
P.S. if it helps, the answer is 2pi(41L/45g)^0.5, I'd just love to know how to get to that.
OK so another update. I just realized I'm one digit off--because the answer is 82/90, not 83/90. I think the error must be with finding the Icm, because everything would simplify properly if Icm=0.01 instead of 0.02. I'm just confused as to why Icm would only be with regards to one mass instead of both...
FIGURED IT OUT:
No parallel axis theorem and now the period equation makes sense because we can put in 2m instead of m-->
Solution:
rcm=(r1m+r2M)/(m+M)
rcm=[(L+0.8L)m)]/2m
Icm=mr^2+mr^2
Icm=m(1L)^2+m(0.8L)^2
Icm=1.64L^2
T=2pi(I/Hgm)^0.5
T=2pi(1.64mL^2/0.9Lg2m)^0.5
T=2pi(82L/90g)^0.5
T=2pi(41L/45g)^0.5
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jan12-10, 09:22 PM   #2
Recognitions:
Homework Helper Homework Help
Is there a diagram that goes with this? Where's O?
Jan16-10, 08:21 AM   #3
It is a pendulum, thus O is at the opposite end of the rod.
Thread Closed
Thread Tools
Similar Threads for: A Compound Pendulum's Period
Thread Forum Replies
Pendulum's Max Speed Introductory Physics Homework 2
Pendulum's Period Introductory Physics Homework 8
Change in Pendulum's Period with temperature. Introductory Physics Homework 2
Pendulum's and special relativity Introductory Physics Homework 1
Tension in a conical pendulum's string Introductory Physics Homework 1
