Register to reply
Orthogonal Vector to a plane
by TG3
Tags: orthogonal, plane, vector
Share this thread:
TG3
#1
Jan13-10, 06:42 PM
P: 66
The problem statement, all variables and given/known data
Find a nonzero vector orthogonal to the plane through points P (0, -2, 0) Q (4, 1, -2) and R (5,3,1) and find the area of the triangle formed by PQR.
The attempt at a solution
To be honest, I am not entirely sure how to do this problem. I've looked through my textbook and notes, but there is no example that is of the same form of this problem. However, I suspect the cross product is important:
PQ has a vector of <4,3,-2>
RP has a vector of <5,5,1>
Trying to find the cross product I get:
(3--6) - (4-10) + (20 - 15)
Equals 20.
Is that right, and what do I do from here?
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Gavins
#2
Jan13-10, 07:27 PM
P: 27
You're on the right track. Those 2 vectors you have are parallel to your plane. If you compute the cross product between them, you will get a new vector perpendicular to the 2 vectors and hence perpendicular to the plane. Do you know how to compute the cross product? What you get should be a vector. The next bit relies on the geometric definition of the cross product.
Go over on computing the cross product as it's all you'll need.
http://en.wikipedia.org/wiki/Cross_product
TG3
#3
Jan13-10, 08:31 PM
P: 66
Wow, epic fail. Thanks!
Register to reply
Related Discussions
Orthogonal projection of 2 points onto a plane Differential Geometry 5
Orthogonal Projection onto XY plane Calculus 9
Finding a vector orthogonal to others Linear & Abstract Algebra 18
A-orthogonal vector set Linear & Abstract Algebra 4
Equation of a plane orthogonal to a vector Introductory Physics Homework 46
