Thread Closed
on bohr- sommerfeld theory
Share Thread Thread Tools
Jan15-10, 10:39 PM   #1
So when relativity is applied to an orbiting electron, you get:
[tex]p_{\varphi}=mr^2 \dot{\varphi}, \quad m=\frac{m_{0}}{\sqrt{1-\beta^2}}, \quad \beta=\frac{v}{c} [/tex]
Change the rectangular coodinates into the polar coordinates,
[tex] x = r cos \varphi, \qquad y = r sin \varphi [/tex]
The nucleus is at the origin. The equation of motion is (the Coulomb force condition),
[tex]\frac{d}{dt}m\dot{x}= - \frac{kZe^2}{r^2}cos \varphi, \quad \frac{d}{dt}m\dot{y}= - \frac{kZe^2}{r^2}sin \varphi[/tex]
Using the next condition (the angular momentum [tex]p_{\varphi}[/tex] is the constant),
[tex]\frac{d}{dt}= \frac{d\varphi}{dt} \frac{d}{d\varphi}= \frac{p_{\varphi}}{mr^2} \frac{d}{d\varphi}[/tex]
So the equation of the motion is ([tex]u= 1/r[/tex]),
[tex]\frac{d}{dt}m\dot{x}= - \frac{p_{\varphi}^2}{mr^2}(u+\frac{d^2 u}{d\varphi^2}) cos \varphi[/tex]
In the case of y, change the upper cos into sin. Combine this with the Coulomb force condition,
[tex]\frac{d^2 u}{d \varphi^2}+u = \frac{kZe^2 m_{0}}{p_{\varphi}^2} \frac{1}{\sqrt{1-\beta^2}} [/tex]
Using the energy [tex]W[/tex] (of #4) and erase the [tex]\beta[/tex], the solution can be expressed as,
[tex]u = \frac{1}{r} = C (1+ \epsilon cos \gamma \varphi)[/tex]
And, the condition of the quantization is, (using the partial integration)
[tex]\oint p_{r}dr= p_{\varphi} \epsilon^2 \gamma \oint \frac{sin^2 \varphi d \varphi}{(1+\epsilon cos \varphi)^2} = p_{\varphi} \gamma \oint (\frac{1}{1+\epsilon cos \varphi}-1) d\varphi=n_{r} h[/tex]
And, we should use the following mathematical formula, too,
[tex]\frac{1}{2\pi} \oint \frac{d \varphi}{1+ \epsilon cos \varphi} = \frac{1}{\sqrt{1-\epsilon^2}} [/tex]
my question is, assuming r= radius, how does momentum = mr and furthermore p(lorentz)=mr^2(lorentz)
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: on bohr- sommerfeld theory
Thread Forum Replies
Lie algebras and Bohr-Sommerfeld conditions General Physics 1
Bohr-Sommerfeld Quantization question General Physics 9
Mathematical Basis of Bohr-Sommerfeld Math & Science Software 1
Bohr-Sommerfeld QFT? General Physics 0
