What is the Efficiency of a Carnot Air Conditioner?
The problem involves a Carnot air conditioner that transfers thermal energy from a room at 70 degrees F to the outdoors at 96 degrees F. The original poster seeks to determine how many joules are removed from the room for each joule of electric energy consumed by the air conditioner.
  • The original poster attempts to apply the Carnot efficiency equation and questions whether the work done by the air conditioner should be included in the total energy removed from the room. Other participants discuss the Coefficient of Performance (COP) and its relevance to the problem.
Participants are exploring different interpretations of the problem, particularly regarding the inclusion of work in the energy removed from the room. Some guidance has been offered regarding the COP, but there is no explicit consensus on the correct interpretation of the problem.
There is uncertainty regarding the rounding of the answer in the textbook and whether the work done by the air conditioner is considered part of the energy removed from the room.
azure kitsune
A Carnot air conditioner takes energy from the thermal energy of a room at 70 degrees F and transfers it to the outdoors, which is at 96 degrees F. For each joule of electric energy required to operate the air conditioner, how many joules are removed from the room?
[tex]\frac{Q_C}{Q_H} = \frac{T_C}{T_H}[/tex]
I substituted W + QC for QH. Then I plugged in
W = 1,
TC = (70-32) * 4/5+273,
TH = (96-32) * 4/5+273
and solved for QC.
I get QC = 20.3 J, but the answer in the back is rounded 21 J. When I read the problem, I thought the question was asking for QC. Should the 1 J or work be included in the amount of joules being removed from the room?
Hello,
A Carnot cycle operating as a reverse heat pump (i.e. air conditioner) has a Coefficient of Performance (COP) this is similar to an efficiency but since it's value can be greater than 1 so it has the alternative name Coefficient of Performance. The COP can be defined as the ratio of the heat extracted from a low temperature source to the work done to accomplish that extraction.
For this application the COP can be calculated as
COP = 1 / ((Th / TL) - 1)
where Th is the higher temperature and TL is the lower temperature.
Then you can use this relation
COP = QL / W
Does that help you out?
Thanks
Matt
Hi Matt, thanks for your reply. I tried to use the equations you gave for COP, but I still end up with QL = 20.3 J.
Maybe just a typ in the book?
That's possible, but I think I may be understanding the problem incorrectly. Maybe the 1 J of work done by the machine is also included in the "joules" that "are removed from the room." (in which case the problem would be asking for QH)
