| Thread Closed |
Why can any two phases be connected together? |
Share Thread | Thread Tools |
| Jan19-10, 07:31 AM | #52 |
Why can any two phases be connected together?http://www.animations.physics.unsw.e...ors.html#three Edit: Oops. I thought you were asking about foos images. |
| Jan19-10, 11:22 AM | #53 |
Here is another way to illustrate my point (hopefully the pictures will help):
If I have four D-Cell batteries connected in series like this: ![]() and measure them with a voltmeter, I get 6 volts. As you can see the batteries are all "in phase" with each other. That is, the direction of their polarity is consistent. Now, if I reverse the meter leads like this: ![]() the meter reads -6 volts. Did the voltage of the batteries change? No! I'm just looking at them differently; they are all still "in phase" with each other. Now,if I measure from one end of the series-connected batteries to the middle connection (the center-tap) like this: ![]() I now get a reading of 3 volts. And, if I measure from the middle connection to the other end of the series-connected batteries like this: ![]() I still get a reading of 3 volts. However, if I now move my red (positive) probe back to the other end of the series-connected batteries, leaving the black (negative) probe at the middle connection like this: ![]() I get a reading of -3 volts. This is similar to how most people view a 240/120V 3-wire single-phase connection. The phasing (or, in the case of the DC batteries, the polarity) of any part of the system never reverses, only the way we choose to look at it does. Just as the upper 2 batteries in my diagrams are always "in phase" with the lower 2 batteries, one half of a coil is always in phase with its other half. |
| Jan19-10, 12:33 PM | #54 |
zgozvrm, I get it. I've always 'gotten it'. I just don't understand why you insist that a center tapped winding cannot be considered to have each end of the coil 180 degrees out of phase with each other when the voltage is referenced to the center tap. But somehow, you claim that having two completely seperate windings that it is ok to call them 180 degrees out of phase with each other when the scope is hooked accordingly. So then do you feel that you can no longer call them 180 degrees out of phase if you were to hook the seperate windings together end to end? This essentially would become a single center tapped winding. Many power transformers are configured like this. To me it looks like this: I stand facing North. I can say for fact that the sun gets up to my right and sets to my left. Then I stand facing South and I say that now the sun gets up to my left and sets to my right. You argue that I cannot say that because I'm just facing the wrong way. I no longer wish to argue this specific point. However, I would still like your opinion to the question I asked about manufacturing a new 'phase' or 'leg' or whatever you prefer to call it.
| Jan19-10, 12:56 PM | #55 |
Well, Averagesupernova, it sounds like we're arguing about the same thing ... it's all about point of view/point of reference. My point is (and always has been) that there is only one voltage phase being generated on the secondary side of a single phase transformer. When we choose to split it and look at the 2 halves differently, (let me be clear about this) it appears to look like 2 different phases. In actuality, it's 2 parts of the same phase looked at differently so that they appear to be 180 degrees out of phase. And yes, in reference to the center tap, they are 180 degrees out of phase.
As for your question about "manufacturing" 3-phase from a single phase source, my answer is, "Of course not." If the 3 voltages measured between each of the 3 legs of power source A are all at the same amplitude and at the same angular displacement from each other, and the same holds true for power source B, I obviously could not tell the difference between the two. I still don't understand the point of the question, though (or how it relates to the discussion of the thread). |
| Jan19-10, 02:13 PM | #56 |
| Jan19-10, 02:40 PM | #57 |
Now, looking back, I guess I could tell one 3-phase voltage source from the other, if you told me that one was delivered using a 3-phase transformer, and the other with a Scott-T transformer (and their associated ratings). By measuring voltage, I would not be able to tell, but by loading the voltage sources down and measuring amps I could tell you one from the other (or loading them down until one failed - the Scott-T, being less efficient). Or, if you allowed me to have the power turned off, some resistance measurements would tell me which one was which. BTW - none of this really relates to the OP's original question which had to do with trying to understand how two legs of a 3-phase power source could possible complete a circuit with a load connected between them ... he seemed to think that a neutral wire was necessary to "return the current." |
| Jan19-10, 02:52 PM | #58 |
I didn't ask if it could be done, I asked if you could tell. And no, it was assumed your only tools would be a scope and voltmeter without turning the power off and no loading. Sorry for not being more specific. Thank you.
| Jan19-10, 02:52 PM | #59 |
If you know of a way to do this (without electronics), I'd like to see it. I'm not saying that it can't be done, I just don't know how. |
| Jan19-10, 04:13 PM | #60 |
I am not specifically familiar with Scott-T. I have heard of it. What I had in mind was electronic. Actually, the reason I said
| Jan19-10, 09:08 PM | #61 |
That ROCKS! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Why can any two phases be connected together?
| Connected vs. Path Connected Sets | Differential Geometry | 6 | ||
| Capacitors Connected, Disconnected, and Connected Again | Introductory Physics Homework | 1 | ||
| An open connected set is path(polygon) connected | Calculus | 1 | ||
| Is every subspace of a connected space connected? | General Math | 12 | ||
| (connected and locally path-connected) ==> (path-connected) | Calculus & Beyond Homework | 1 | ||
