How Does Current Affect Spring Extension in a Magnetic Field?
  • Thread starter Thread starter Sam_The_Great
    Currents Springs
The discussion focuses on calculating the current flowing through a wire that stretches a spring with a spring constant K of 20 N/m when subjected to a magnetic field of 0.5 T. The spring is stretched 1 cm from its equilibrium position, and the force on the current-carrying wire in the magnetic field is given by the formula F = ILB. To find the current I, one must equate the force exerted by the spring (F = -kx) to the magnetic force (F = ILB), leading to the conclusion that the current can be determined using these established physics principles.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of the magnetic force on a current-carrying conductor
  • Familiarity with basic electromagnetic principles
  • Ability to manipulate algebraic equations to solve for unknowns
  • Study the derivation of Hooke's Law and its applications in mechanical systems
  • Learn about the Lorentz force and its implications in electromagnetism
  • Explore the relationship between current, magnetic fields, and forces in more complex circuits
  • Investigate practical applications of springs and electromagnetism in engineering
Physics students, electrical engineers, and anyone interested in the interplay between mechanical systems and electromagnetic forces will benefit from this discussion.
Sam_The_Great
I have the following problem on which I am unsure how to proceed.
A spring with a spring constant K = 20 N/m is shown below. It is stretched 1 cm from its equilibrium position when a current I passes through the wire. How big is the current in the wire?
The magnetic field is coming out of the page and is B = .5T, the length of the area is 20cm.
_________________________
| || | 20 cm
|_______||________________|
You'll need to know the force on a current-carrying wire in a magnetic field: F = ILB, assuming the field is perpendicular to the wire. And you'll need to know about springs: F = -kx.
Thanks
Thanks a lot
  • · Replies 18 ·
  • · Replies 31 ·
