Method to obtain Torsion Constant (structural)
by Su Solberg
Tags: constant, method, obtain, structural, torsion
Su Solberg
Su Solberg is offline
#1
Jan19-10, 08:30 AM
P: 79
Hi every one.
I just wonder whether using Ix+Iy = J is a suitable method to calculate the Torsion Constant of a plate girders (full penetration butt weld at connection section)
Since, as stated at wiki, the polar moment of inertia is only identical to J for circle tube and rod.
p.s. is there any software/calculation method that i can obtain the J and Ixx,Iyy immediately.
Thanks for your kind help in advence.
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
nvn
nvn is offline
#2
Jan19-10, 10:16 AM
Sci Advisor
HW Helper
P: 2,110
No, J = Ix + Iy is not suitable, in this case. In this case, torsional constant (sometimes called K, instead of J) is K = (1/3)*summation(b*t^3), where b = length of each plate component in the cross section, and t = thickness of each plate component.
Su Solberg
#3
Jan19-10, 11:31 AM
P: 79
Quote Quote by nvn View Post
Thanks for your quick reply, brother nvn.
But i think that's for opened thin tube.
The J that I would like to find is as attached.
Btw, could you suggest some notable book name/web-site that I can refer to ?
Thanks again for your kind assistance.
nvn
nvn is offline
#4
Jan19-10, 01:11 PM
Sci Advisor
HW Helper
P: 2,110
Due to post 1, I thought your cross section was open, but now from post 3 I see it is not. I do not have an accurate formula now.
Su Solberg
#5
Jan20-10, 05:30 AM
P: 79
Thanks for your reply.
I wonder what books/ Software I should find to obtain the J?
c quenville
c quenville is offline
#6
Sep17-10, 11:03 PM
P: 1
Quote Quote by Su Solberg View Post
There are a few specialized software to compute the torsion and warping constant. Just Google "torsion constant software". I have successfully used ShapeDesigner in a previous job.
Lazer57
Lazer57 is offline
#7
Sep18-10, 08:25 AM
P: 24
i did a search for "Solidworks torsion constant" to see if there was a way to do it with solidworks/add-ins. i didn't find a way to do it with solidworks but the first hit is to another forum where they discuss it including many programs others have used for that purpose. i don't know if the moderators care if i link to another forum so i will let you find it with that search.
also it seems that the Batho-Bredt theory could be helpful. i don't have the resources or know how to help with that though. there is a google books link that talks about it (5.6 and beyond): http://books.google.com/books?id=hGt...page&q&f=false
another also, i have access to the book: Advanced Applied Stress Analysis by C.T.F. Ross; it talks about the torsional constant and batho-bredt theory.
nvn
nvn is offline
#8
Sep19-10, 01:59 AM
Sci Advisor
HW Helper
P: 2,110
Nice find, Lazer57. Su Solberg, if you post the dimensions of your cross section, we could play around with it, and try the Bredt-Batho formula.
Register to reply
Related Discussions
At what age did you obtain/ plan to obtain Ph.d. Career Guidance 8
Logic: Structural Induction and Tree-method problem! Engineering, Comp Sci, & Technology Homework 1
Logic: Structural Induction and Tree-method problem! Set Theory, Logic, Probability, Statistics 0
Using WKB(J) method to obtain asymptotics for an elastic string? Differential Equations 10
Obtain the time constant from a transfer function General Engineering 1
