Pressure at the boundary between two gas phases which are originally sepearted
This discussion addresses two key questions regarding pressure in gas phases and fluid dynamics. The first question pertains to determining the pressure at the boundary between two gas phases, specifically compressed carbon dioxide and the atmosphere, where applying the ideal gas equation yields different pressures. The conclusion is that the method for determining boundary pressure is not clearly defined in the discussion. The second question examines Pascal's Law, concluding that it does not apply uniformly in flowing fluids, as pressure varies in such conditions.
  • Understanding of the Ideal Gas Law
  • Familiarity with Pascal's Law
  • Basic principles of fluid dynamics
  • Knowledge of gas phase behavior
  • Research methods for determining boundary pressure in gas mixtures
  • Study the implications of fluid flow on pressure distribution
  • Explore advanced applications of Pascal's Law in dynamic systems
  • Learn about the behavior of gases under varying pressure conditions
Students and professionals in physics, engineering, and fluid mechanics who are interested in gas phase interactions and fluid dynamics principles.
eemmann
Hi. I have got two questions...
1. How can we determine the pressure at the boundary of two gas phases (say, compressed carbon dioxide released from a can and the atmosphere) which are originally separated? If we apply the ideal gas equation on each of these two phases, different pressures will be obtained, how do we determine the the value of the pressure at the boundary??
2. The Pascal's Law states that "pressure exerted anywhere in a confined liquid is transmitted equally and undiminished in all directions throughout the liquid". I am wondering if such principle(same pressure at a point in all directions) still holds if the fluid is flowing?
Thanks.
Thanks.
With regard to the first question, what is being asked is not clear.
With regard to the 2nd question: No. In a flowing fluid, the pressure is not uniform.
  • · Replies 0 ·
