Thread Closed
turbulence in fluid in a pipe
Share Thread Thread Tools
Aug12-04, 08:30 AM   #1
Kurious:
>Can a pipe exist so that if a bump on its inner surface causes some turbulence in a >passing fluid,other bumps further along the path of the fluid could remove the >turbulence?
Kurious:
I would guess that the answer to this is yes because if enough bumps were put in the pipe in the right places, the pipe would get a smooth surface.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Aug12-04, 08:30 AM   #2
Can a pipe exist so that if a bump on its inner surface causes some turbulence in a passing fluid,other bumps further along the path of the fluid could remove the turbulence?
Aug12-04, 09:34 AM   #3
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\nkurious wrote:\n\n&gt; Can a pipe exist so that if a bump on its inner surface causes some\n&gt; turbulence in a passing fluid,other bumps further along the path of the\n&gt; fluid could remove the turbulence?\n\n\nYou have to be careful with cause and effect here. Flow patterns are\na kind of equilibrium, it is not the right picture that the flow "hits"\na bump, becomes\nturbulent, hits another bump and becomes laminar. Rather, the time scale\nat which determinism operates in flows is acoustic, ie much faster than\nthe flow itself. So the flow "knows" about downstream bumps as it\ninteracts with the first bump, because pressure waves traveling at the\nspeed of sound have already caused many interactions before the first\nvortex is formed.\n\nAdding bumps can sometimes stabilize a flow and make it laminar.\n\nGerard\n\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>kurious wrote:
a bump, becomes
vortex is formed.
Gerard
Aug13-04, 05:41 AM   #4
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n&gt;From: kurious alistair@goforit64.fsnet.co.uk\n\n&gt;Can a pipe exist so that if a bump on its inner surface causes some\n&gt;turbulence in a passing fluid,other bumps further along the path of the\n&gt;fluid could remove the turbulence?\n\nWell, sort of. In general, a gently widening or narrowing passage can\nfacilitate the transition from laminar to turbulent flow or back to laminar.\nAn included angle of greater than 14 degrees in an expansion transition almost\ninevitably induces turbulence.\n\nThe radial distribution of the axial velocity component in laminar flow is\nparabolic, peaking in the center of a round pipe. The distribution in turbulent\nflow is more "squared off", more even throughout the pipe. At certain Reynold\'s\nNumbers, one can usually count on the transition, be the flow air or water,\nfluid, liquid or gas.\n\nI\'m sorry, I don\'t have my Fluid Mechanics text here.\n\nWhat constitutes a "bump"?\n\n\nYours,\n\nDoug Goncz ( ftp://users.aol.com/DGoncz/incoming )\nStudent member SAE for one year.\nI love: Dona, Jeff, Kim, Mom, Neelix, Tasha, and Teri, alphabetically.\nI drive: A double-step Thunderbolt with 657% range.\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>>From: kurious alistair@goforit64.fsnet.co.uk
flow is more "squared off", more even throughout the pipe. At certain Reynold's
I'm sorry, I don't have my Fluid Mechanics text here.
Yours,
Aug16-04, 12:55 PM   #5
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n&gt; Can a pipe exist so that if a bump on its inner surface causes some\n&gt; turbulence in a passing fluid,other bumps further along the path of the\n&gt; fluid could remove the turbulence?\n\nTheoretically yes, although this would not require a bump but, as Doug\npoints out, narrowing the pipe. However in normal conditions, a flow that\nbecomes turbulent (sufficiently high above Ra_crit) quickly features a\ncontinuous range of length-scales, from the diameter of the pipe to the\nKolmogorov lengthscale. The route in which the fluid becomes turbulent is\nstill not fully understood, but Ruelle and Takens picture the instabilities\ngoing through two Hopf-bifurcations and then immediately onto a strange\nhigher-dimensional attractor, featuring a range of lengthscales.\n\n&gt;From your answer I sense you are thinking in lines of putting the bumps in\ncounter-phase with the turbulence, but as there\'s a large range of scales\ninvolved this is impossible to achieve. Furthermore you would have to have\nthe phases right, which is impossible as this can differ from realisation\nto realisation.\n\nRegards,\n\nMaarten van Reeuwijk\n\n--\n===================================================================\n Maarten van Reeuwijk Thermal and Fluids Sciences\nPhd student dept. of Multiscale Physics\nwww.ws.tn.tudelft.nl Delft University of Technology\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Can a pipe exist so that if a bump on its inner surface causes some
becomes turbulent (sufficiently high above [itex]Ra_crit)[/itex] quickly features a
counter-phase with the turbulence, but as there's a large range of scales
to realisation.
Regards,
Aug17-04, 11:26 AM   #6
val
<jabberwocky><div class="vbmenu_control"><a href="jabberwocky:;" onClick="newWindow=window.open('','usenetCode','toolbar=no,location=no, scrollbars=yes,resizable=yes,status=no,width=650,height=400'); newWindow.document.write('<HTML><HEAD><TITLE>Usenet ASCII</TITLE></HEAD><BODY topmargin=0 leftmargin=0 BGCOLOR=#F1F1F1><table border=0 width=625><td bgcolor=midnightblue><font color=#F1F1F1>This Usenet message\'s original ASCII form: </font></td></tr><tr><td width=449><br><br><font face=courier><UL><PRE>\n\n\nHello,\nWhat about putting a grid in the section of the pipe like for tap\nwater for instance before it escapes the pipe. That would reduce the\nreynold\'s number and maybe the turbulence.\nval\n</UL></PRE></font></td></tr></table></BODY><HTML>');"> <IMG SRC=/images/buttons/ip.gif BORDER=0 ALIGN=CENTER ALT="View this Usenet post in original ASCII form">&nbsp;&nbsp;View this Usenet post in original ASCII form </a></div><P></jabberwocky>Hello,
reynold's number and maybe the turbulence.
val
Thread Closed
Thread Tools
Similar Threads for: turbulence in fluid in a pipe
Thread Forum Replies
fluid motion in a pipe Classical Physics 6
Fluid - Determining pump power for pipe flow system Engineering, Comp Sci, & Technology Homework 1
fluid 'light-pipe' General Physics 4
Fluid Mechanics - Pipe Flow Mechanical Engineering 11
viscous fluid moving in a pipe Introductory Physics Homework 1
