Proving Derivative of sin(x)/x is Zero at x=0
  • Context: Undergrad
  • Thread starter Thread starter mherna48
    Derivative Zero
The discussion revolves around proving that the derivative of the function sin(x)/x is zero at x=0. The scope includes mathematical reasoning and the application of calculus concepts such as limits and differentiability.
  • One participant suggests using the definition of differentiability and applying l'Hopital's rule or series expansion to prove the limit exists.
  • Another participant points out that f(0) = sin(0)/0 is not defined, raising a concern about the initial function's definition at that point.
  • A later reply proposes that the discussion may be about the sinc function, which extends the definition of f(x) = sin(x)/x to include f(0) = 1 by continuity.
Participants express differing views on the definition of the function at x=0, with some suggesting the use of the sinc function while others focus on the original function sin(x)/x. The discussion remains unresolved regarding the approach to proving the derivative.
There are limitations regarding the assumptions about the function's definition at x=0 and the applicability of l'Hopital's rule or series expansion without resolving the undefined nature of sin(0)/0.
mherna48
Hey can anyone help me prove that the derivative of sin(x)/x is zero at x=0
A function f:R -> R is differentiable at 0 if
[tex]\lim_{h \rightarrow 0}\frac{f(h)-f(0)}{h}[/tex]
exists. You can apply this definition and then use l'Hopital's rule or perhaps some first-order estimates to show that this last limit exists. Alternatively, you can probably work directly with the series expansion for sin.
But f(0) = sin0/0 is not defined
Well I took it that the OP actually meant the sinc function, which just extends f(x) = sin(x)/x by continuity so that f(0) = 1.
