Rocket Acceleration: Calculating Speed and Altitude
The discussion revolves around a physics problem involving the launch of a weather rocket, focusing on its acceleration during the initial phase and its speed at a specific altitude. The problem is situated within the context of kinematics and motion under gravity.
  • Participants discuss the use of kinematic equations to determine the rocket's acceleration and speed. There are attempts to clarify the initial conditions and the effects of gravity after the motor stops. Some participants question how to approach the problem and express uncertainty about starting points.
There is an ongoing exploration of different approaches to the problem, with some participants suggesting focusing on the last seconds of the rocket's flight after the engine cuts off. Guidance has been offered regarding the use of kinematic equations and the relationship between acceleration and velocity at different phases of the rocket's flight.
Participants note the absence of air resistance and the assumption that the rocket starts from rest. The discussion also highlights the need to consider the effects of gravity once the rocket motor stops.
mullets1200
A 1000kg weather rocket is launched straight up. The rocket motor provides a constant acceleration for 16s, then the motor stops. The rocket altitude 20s after launch is 5100m. There is no air resistance.
Questions:
What was the rocket's acceleration during the first 16s?
What is the rocket's speed as it passes through a cloud 5100m above the ground
Questions:
Equations?
And your attempts with them?
pgardn said:
Equations?
Equations:
I think you use the equation: r=Vit+.5a(t)2
Im not sure where to start though that is the problem
mullets1200 said:
Equations:
You are going to need your other kinematic equations.
I would start by looking at the last 4 seconds of the rockets trip (when the only force acting on the rocket is gravity thus a = g = -9.8m/s/s) because the engine has cut off. So when the engine cuts off at 16 seconds you have reached your maximum velocity. After that, during the last 4 seconds the rocket will be slowing down (accelerating down). At the end of this 4 seconds the rocket will be going 0 m/s presumably as it has reached its maximum height.
So why not find the velocity of the rocket when the engine cut off. You got a = g, you got t, and you got Vf = 0 m/s ... find Vo which will be the velocity when the engine cuts off...
Then look at the first 16 s during which the rocket is accelerating up. You have t, you have Vf from the above (it is really Vo from the above), you have Vo = 0 m/s (I will assume the rocket started from rest from the lauch pad) and solve for a.
This is one way to go about it.
26K
10K
