Relationship between coefficients of linear and volume expansion
by madmartigano
Tags: coefficients, expansion, linear, relationship, volume
madmartigano
madmartigano is offline
#1
Jan24-10, 05:11 PM
P: 2
If a solid material is in the form of a block rather than a rod, its volume will grow larger when it is heated, and a coefficient of volume expansion beta defined by
[tex]\beta = \frac{{{V_2} - {V_1}}}{{{V_1}\left( {{t_2} - {t_1}} \right)}}[/tex]
may be quoted. Here [tex]{V_1}[/tex] and [tex]{V_2}[/tex] are the initial and final volumes of the block, and [tex]{t_1}[/tex] and [tex]{t_2}[/tex] are the initial and final temperatures. Find the relation between the coefficients [tex]\alpha[/tex] and [tex]\beta[/tex].
2. Relevant equations
[tex]\alpha = \frac{{{L_2} - {L_1}}}{{{L_1}\left( {{t_2} - {t_1}} \right)}}[/tex]
3. The attempt at a solution
I'm assuming I need to set [tex]{V_1} = {L_1}{W_1}{H_1}[/tex] and [tex]{V_2} = {L_2}{W_2}{H_2}[/tex]
and attempt to extract [tex]\frac{{{L_2} - {L_1}}}{{{L_1}\left( {{t_2} - {t_1}} \right)}}[/tex] from [tex]\frac{{{L_2}{W_2}{H_2} - {L_1}{W_1}{H_1}}}{{{L_1}{W_1}{H_1}\left( {{t_2} - {t_1}} \right)}}[/tex]
I've only gotten so far:
[tex]{W_1}{H_1}B = \frac{{{L_2}{W_2}{H_2} - {L_1}{W_1}{H_1}}}{{{L_1}\left( {{t_2} - {t_1}} \right)}}[/tex]
but I can't figure out the rest of the algebraic manipulation.
Is this possible, or am I going about the problem incorrectly?
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
ideasrule
ideasrule is offline
#2
Jan24-10, 08:29 PM
HW Helper
ideasrule's Avatar
P: 2,324
Quote Quote by madmartigano View Post
Now, express L2, W2, and H2 in terms of L1, W1, and H1. Remember that the linear expansion equation, [tex]\alpha = \frac{{{L_2} - {L_1}}}{{{L_1}\left( {{t_2} - {t_1}} \right)}}[/tex], applies for the width and height too.
A less messy way to do this problem is to write the linear expansion equation as Lf=Li(1+alpha*delta-T). Then LWH=Li(1+alpha*delta-T)*W*(1+alpha*delta-T)...you get the idea.
That step is correct algebraically, but it gets you farther from the solution.
madmartigano
#3
Jan24-10, 11:10 PM
P: 2
You helped me see that I was just over-thinking the problem--I got it figured out. Thank you.
Register to reply
Related Discussions
Coefficients of expansion and compressibility Advanced Physics Homework 7
What is the relationship between finite differences and the leading coefficients? Precalculus Mathematics Homework 1
relating coefficients of volume, linear expansion with height Introductory Physics Homework 0
volume expansion problem...wheres initial volume? Introductory Physics Homework 2
Expansion Coefficients Quantum Physics 6
