Thread Closed
Using a Hall Effect sensor IC for high fields
Share Thread Thread Tools
Jan28-10, 10:51 PM   #1
I'm trying to use IC hall effect sensors for a school project *not homework, rather an ungraded research project*. Basically, we are trying to measure the magnetic field gradient inside of an experiment chamber. The chamber is surrounded by two huge copper coils that have about 1000A running through them - the magnitude of the B field is ~900 gauss max.
Problem is, the only hall effect sensors i can find max out at around 800 gauss. The sensors we are trying to use now are made by optek (3150), and are easy to use but have too high of a sensitivity. Is anyone familiar with a way we can extend the range of fields we can measure? I thought about using magnetic shielding (wrapping the sensors in mu metal or something similar), but this is problematic and I was hoping for a more accurate solution. Any suggestions?
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Jan28-10, 11:03 PM   #2
Recognitions:
1000 amps in a school project? Are you sure?
Hall probes are sensitive to fields at right angles to the front surface, so you could possibly have a greater field at, say, 45 degrees to this surface?
So, if you located the direction of the field and rotated the probe by some fixed angle, maybe you could calibrate it that way for the actual field.
Shielding materials may become projectiles at high magnetic fields.
Jan28-10, 11:08 PM   #3
Digikey (www.digikey.com) has these Alegro Micro linear analog Hall Effect sensors in stock for about $3.99 ea (unit price). Their sensitivity is about 0.7 to 1.4 mV per volt. See
http://www.allegromicro.com/en/Produ.../1360/1360.pdf
Bob S.
Jan28-10, 11:15 PM   #4
thanks for the suggestion. Only problem is, we don't know the exact field strength (900 gauss is the field at which cyclotron resonance occurs, but the field may be much higher in areas) and I'm worried that the sensors will still saturate even at a 45 degree angle. I also had someone suggest that we try decreasing the temperature of the sensors using liquid nitrogen to decrease the sensitivity of the sensors, but that introduces uncertainties...
Quote by vk6kro View Post
yup. I'm trying to make level curves of the field strength in an electron cyclotron resonance (ECR) machine, which we use for plasma processing of semiconductor wafers. The magnetic field is generated by two huge axial toroidal copper coils; the field resembles a magnetic bottle, if you want to visualize it.
Jan28-10, 11:27 PM   #5
Quote by Bob S View Post
Bob S.
Beautiful. .7mv/Gauss is exactly what I need, thanks.
Jan29-10, 02:34 AM   #6
At the extremes, you can build a coil around the sensor and drive towards / at null. I don't know how reasonable this is off hand due to the power dissipation of the coil, but I seem to recall driving one to 550 Gauss / Oersted once without too much fuss.
In any case, if your coil gets hot, you can always take short readings.
- Mike
PS Beware hall sensors bearing magnetic materials inside...
Jan29-10, 01:31 PM   #7
Quote by Mike_In_Plano View Post
Some nonlinear bipolar switch Hall Effect sensors may have some magnetic material in it, but the linear analog sensors don't.
For a complete list of Allegro Hall Effect devices, see
http://www.allegromicro.com/en/Produ...sors/index.asp
Bob S
Thread Closed
Thread Tools
Similar Threads for: Using a Hall Effect sensor IC for high fields
Thread Forum Replies
what is Spin Hall effect and quantum hall effect Quantum Physics 1
implementing Hall Effect Sensor Electrical Engineering 5
hall sensor quiescent voltage to zero Electrical Engineering 11
Hall Effect Classical Physics 0
Hall Effect!!!! Introductory Physics Homework 0
