Thread Closed
Mechanics!!
Share Thread Thread Tools
Jan30-10, 04:29 AM   #1
Mechanics!!
A cliff diver takes off horizontally from a cliff face 26.5 metres above the surface of the water. In the course of his flight, he travels 8 metres forwards, of which all but the last 1.5 metres of horizontal motion is above rock. In other words, he travels 6.5 metres in the air horizontally, before he falls and travels the remaining 1.5 metres.
Questions:
1) How long is he in the air?
s = 1/2 (g) (t^2), so time =2.3 seconds
2) How long is he OVER the water during the flight?
I assume this is asking how long he travels at the 6.5 metres?
I have no idea what equation to use or where to start - all i know is that the answer is 0.44 seconds...HELP!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan30-10, 07:24 AM   #2
Quote by Badrakhandama View Post
A cliff diver takes off horizontally from a cliff face 26.5 metres above the surface of the water. In the course of his flight, he travels 8 metres forwards, of which all but the last 1.5 metres of horizontal motion if above rock. In other words, he travels 6.5 metres in the air, horizontally
I don't understand this exercise. Isn't "he travels 8 metres forwards" and "he travels 6.5 metres in the air, horizontally" a contradiction?
I interpreted it as 6.5m of the horizontal motion was above rock since the rock face is not vertical, and the last 1.5m is above water. So "he travels 6.5 metres in the air, horizontally" would be incorrect, no?
Torquil
Jan30-10, 07:55 AM   #3
Hi - It is my fault - I have phrased it poorly.
The Diver takes off and travels forward 8 metres, by the time he has hit the water - however, 6.5 metres of the 8 is covered above the rock. The other 1.5 metres is covered as he is now falling down past the rock.
Jan30-10, 08:06 AM   #4
Mechanics!!
Ok, then I understand more. You have already found the amount of time. You can assume that the horizontal component of the velocity is constant since there are no horizontal forces acting (neglecting wind resistance), so you can figure out the horizontal speed.
From that you should be able to find the answer to the second question.
Torquil
Jan30-10, 08:24 AM   #5
I agree - but I do not appear to get the answer of 0.44 seconds.
This is how I did it -
If t = 2.3 seconds
Speed = d/t =8/2.3 = 3.5 metres per second
Assuming velocity remains the same (which it does), then to travel 6.5 metres will take :
T = d/s = 6.5/3.5 = 1.87 seconds.
What am i doing wrong?
Jan30-10, 08:32 AM   #6
I don't think you did anything wrong apart from misinterpret your result. Your time is the time above rock, so you want the difference between those time values.
Torquil
Jan30-10, 08:37 AM   #7
Thank you! That gives the correct answer.
But I have one question - If it takes 2.3 seconds to travel 8 metres, and takes 1.87 seconds to travel 6.5 metres - then why is the answer not 1.87? Since the time above the rock is the time taken to travel 6.5 metres, right?
Jan30-10, 08:40 AM   #8
Wait - maybe I am misinterpreting the whole question - when is says ' how long over the water,' what does that mean?
Thank You
Jan30-10, 08:45 AM   #9
It means that they want the amount of time during which he has water directly beneath him. So that would be the time it takes to move the last 1.5m.
Torquil
Jan30-10, 08:52 AM   #10
Ok, but he has water beneath him for all 8 metres.
The question does not say that he runs 6.5 metres and then falls, it says he travels 8 metres in the air...
So i am not sure
Jan30-10, 09:00 AM   #11
I think it is like this: He jumps out from the rock face. the rock face is not vertical, so he has to jump at least 6.5m out to awaid being smashed on the rocks. He jumps out 8m to be sure to not hit the rocks.
So in total: 8m horizontally. 6.5 of them while with rocks underneat, and the other 1.5 with water underneath.
Torquil
Jan30-10, 09:10 AM   #12
Ah! That makes much more sense! Thank You
Finally, make I ask you - how could you calculate 'the angle which the diver makesm to the vertical, upon entry to the water?'
Jan30-10, 09:11 AM   #13
Oh! That seems right - thank you very much!
One last question - how do you calculate 'the angle which the diver makes, to the vertical, upon entry to the water' ???
Thank You, again
Jan30-10, 09:17 AM   #14
No problem, you already know the horizontal speed upon impact. Since you know the total time you can also calculate vertical speed. After that you should be ble to find the angle using a trigonometric function.
Torquil
Jan30-10, 09:24 AM   #15
Yes, I have got the horizontal speed to be 3.5 metres per second
The vertical speed is 11.5 metres per second
But what trignometric function? I do not know of any which can predict the vertical entry angle of a perabola
Jan30-10, 09:39 AM   #16
Jan30-10, 09:39 AM   #17
I'll only tell you that it is sin, cos, or tan. You can check their definitions here:
http://en.wikipedia.org/wiki/Trigonometric_function
Good luck!
Torquil
Thread Closed
Tags
angle, mechanics, speed, velocity, voltage
Thread Tools
Similar Threads for: Mechanics!!
Thread Forum Replies
hydrogen atom obeying classical mechanics rather than quantum mechanics Introductory Physics Homework 6
Is it possible to take statistical mechanics without quantum mechanics? Academic Guidance 5
Fracture mechanics versus Damage mechanics Classical Physics 2
The Bug and the Rod: AP Physics Mechanics Section II Mechanics 2 Advanced Physics Homework 0
Transition from classical continuum mechanics to point mechanics? General Physics 2
