Circular Motion
by dragonladies1
Tags: circular, motion
dragonladies1
dragonladies1 is offline
#1
Feb1-10, 06:50 PM
P: 23
For this problem, I tried using the equation:
ac=V2/r and put in
2000= ((2*pi*r)/(1/58))2*r
What is the distance of a sample of blood from the rotation axis of a centrifuge rotating at a frequency f = 3480 rpm, if it has an acceleration of 2000g?
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
berkeman
berkeman is online now
#2
Feb1-10, 07:10 PM
Mentor
berkeman's Avatar
P: 39,716
Quote Quote by dragonladies1 View Post
ac=V2/r and put in
I'm not understanding your equation (made harder to understand because no units are shown).
Use a = omega^2 * r instead (close to the form of your equation anyway), and carefully convert 3480rpm into the omega (show the units in your conversion to check yourself).
dragonladies1
#3
Feb2-10, 11:38 AM
P: 23
Human blood contains plasma, platelets, and blood cells. To separate the plasma from other components, centrifugation is used. Effective centrifugation requires subjecting blood to an acceleration of 2000g or more. In this situation, assume that blood is contained in test tubes of length L = 14.3 cm that are full of blood. These tubes ride in the centrifuge tilted at an angle of 45.0 above the horizontal (see figure below)
(a) What is the distance of a sample of blood from the rotation axis of a centrifuge rotating at a frequency f = 3480 rpm, if it has an acceleration of 2000g?
cm
(b) If the blood at the center of the tubes revolves around the rotation axis at the radius calculated in Part (a), calculate the accelerations experienced by the blood at each end of the test tube. Express all accelerations as multiples of g.
minimum acceleration g
maximum acceleration g
This is the entire problem.
So for the first part:
a=omega^2*r
a= (2*pi*r/(1/58))^2*r
What am I doing incorrectly?
Register to reply
Related Discussions
Circular Motion, Center of Gravity, Rotational Motion Homework Help Introductory Physics Homework 1
Identifying the forces in a difficult circular / non-circular motion hybrid problem. Introductory Physics Homework 5
Simple Harmonic Motion- From Uniform Circular Motion Introductory Physics Homework 5
Uniform Circular Motion, Rotational Motion, Torque, and Inertia General Physics 1
Motion in a Plane question dealing with circular motion Introductory Physics Homework 11
