Thread Closed
Two Springs and Two Masses. Equation of Motion
Share Thread Thread Tools
Feb1-10, 11:37 PM   #1
Derive the equation of motion for the following Mechanical System. You need to introduce an additional variable to represent position of the bottom mass.
I drew a picture ;D
http://www.mediafire.com/imageview.p...mimmwd&thumb=4
2. Relevant equations
EOM:
Mx(double Dot) = reactionary forces
Bx(dot) is the damping effect: B = damping coefficient times the velocity
3. The attempt at a solution
Now, this is apparently a vibration type problem. But I'm assuming too many things when trying to write the Eq. of Motion.. so I don't feel confident about the question. When the K1 spring is pulled towards the right, M1 stars moving towards the right... Obviously.. Now, a few questions come up, the figure assumes that M2 has a direction to right ( Atleast I think.. thats the Xout in the picture). So what does that mean? The friction between M1 and M2 is static friction so M2 does not slide and just moves to the right until spring K2 pulls it back and then Kinetic friction comes in.
But I was told by a few people, to not think of this as having friction but actually like the masses are damping each others velocities. So the Eq. Of Motion would have Bx(dot) instead of a couple of Kx.
I just need a little bit of direction on this problem.
Heres what I have come up with.
Assuming M2 slides the opposite way as M1 moves to the right. So M2 basically oscillates back and forth just a tiny bit as the bigger mass M2 moves right and left.
So that means that the two masses provide a damping effect on each other.
So if i was to write the EOM: [ displacements have to be defined in the figure obviously so just assume that I defined them right]
(M1 + M2)x(double dot) = K1(X3 - X2) - Bx(dot) - Bx(dot) - K2(Delta S)
But I'm not confident about this because I'm not sure I get the whole scenario conceptually.
Thanks For The Help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Thread Closed
Thread Tools
Similar Threads for: Two Springs and Two Masses. Equation of Motion
Thread Forum Replies
Simple Harmonic Motion, masses, and springs. Advanced Physics Homework 4
Springs and masses Introductory Physics Homework 4
Springs and Masses Introductory Physics Homework 4
Help on a two masses - two springs system Classical Physics 10
Three Springs and Two Masses Introductory Physics Homework 2
