Calculating Probability of 2+ Homeruns for Baseball Player in 4 At-Bats
  • Context: Undergrad
  • Thread starter Thread starter Muck
    Probability
The discussion revolves around calculating the probability of a baseball player hitting 2 or more homeruns in 4 at-bats, given a 5% chance of hitting a homerun per at-bat. Participants explore different methods for calculating probabilities, including the binomial distribution and combinatorial approaches.
  • One participant presents a method for calculating the probability of hitting 0 or 1 homerun and questions if there is an easier way to count possibilities.
  • Another participant challenges the calculations, asserting that the total probabilities should equal one and provides an alternative calculation for the probability of hitting at least 2 homeruns.
  • A third participant introduces the binomial coefficient formula for calculating the probability of hitting k homeruns in n at-bats.
  • Another participant likens the problem to a Bernoulli trial, suggesting a method based on the total probability of outcomes.
Participants express disagreement regarding the correctness of the initial calculations, with some asserting that the probabilities presented cannot exceed one. Multiple competing views on the calculation methods remain unresolved.
Participants reference different approaches to calculating probabilities, including combinatorial methods and the binomial distribution, but do not resolve the discrepancies in their calculations.
Muck
The question: A baseball player has a 5% chance to hit a homerun each at bat. If the player is up 4 times, what is the chance he hits 2 or more homeruns. I came up with the answer, but this was a long process. I need a formula. And is there an easier way of counting the possibilities?
I did it like this:
Probability of 0 out of 4 + 1 out of 4 = 1.401875
Probability of 0 out of 4 is (0.95)(0.95)(0.95)(0.95)(1) with 1 possibility
Probability of 1 out of 4 is (0.05)(0.95)(0.95)(0.95)(4) with 4 possibilities so
The other 11 possibly scenarios are 6 to do 2 out of 4, 4 to do 3 out of 4, and 1 to do 1 out of 4, for a total of 16 (4x4) but is there an easier way than counting these?
Thank you!
EDIT: for 'player' :)
Your calculations are wrong somewhere. For one, it should be obvious that the first two cases can't have a probability greater than 1, in fact the total probabilities of all the cases should be one. The probability for the first two cases is 0.98598125. Anyways, you can see it was pretty easy to calculate the first two numbers. The probability for 2, 3, or 4 homeruns (i.e. at least 2) is 1 - 0.98598125. You could also calculate it as:
Probability of 2 out of 4 is (0.05)(0.05)(0.95)(0.95)(6) with 6 possibilities
Probability of 3 out of 4 is (0.05)(0.05)(0.05)(0.95)(4) with 4 possibilities
Probability of 4 out of 4 is (0.05)(0.05)(0.05)(0.05)(1) with 1 possibility
Sum those together you'll get the same number as 1 - 0.98598125.
I wasn't aware that it was the baseball that hit the homerun!
Assuming that any batter has probability 0.05 of hitting a homerun at any "at bat", then the probability of a batter hitting k homeruns in n "at bat"s is nCk(0.05)k[/sub](0.95)n-k where nCk is the binomial coefficient: n!/(k!(n-k)!).
Thank you.
This is actually a Bernoulli trial problem that can be seen as tossing a coin, where the chance for heads is .05. Since the total probability is 1 = (H+T)^4. We can just look at 1 minus the tail of the series:
1-4HxT^3-T^4.
