Differential equation with Laplace transform
The discussion focuses on solving the differential equation \( t y'' + (3t-1) y' + 3y = 6 e^{-3t} \) using the Laplace transform. The user attempted to apply the Laplace transform but encountered difficulties, particularly with the terms \( L[t y''] \) and \( L[t y'] \). The correct application of the Laplace transform involves recognizing the negative sign in the derivatives, leading to the equation \( (s^2 + 3s)Y' + (s + 6)Y = \frac{6}{s+3} \). The user is advised to carefully check the application of the transform to avoid errors in the solution.
  • Understanding of differential equations and their standard forms
  • Familiarity with the Laplace transform and its properties
  • Knowledge of initial value problems and boundary conditions
  • Experience with solving equations involving exponential functions
  • Review the properties of the Laplace transform, particularly for derivatives
  • Practice solving initial value problems using the Laplace transform
  • Learn about the inverse Laplace transform and its applications
  • Explore common mistakes in applying the Laplace transform to differential equations
Students studying differential equations, mathematicians focusing on transform methods, and educators teaching Laplace transforms in calculus or engineering courses.
springo
[tex]t y'' + (3 t-1) y' + 3 y = 6 e^{-3t}[/tex]
y(0) = 1
y(5) = 2
I tried applying the Laplace transform to the equation but I was having a little trouble...
L [t·y''] = -dL[y'']/ds = s2·Y' + 2·s·Y - y(0) = s2·Y' + 2·s·Y - 1
L [t·y'] = -dL[y']/ds = s·Y' + Y
Therefore:
[tex]s^2 Y' + 2 s Y - 1 + 3 s Y' +3 Y - s Y + 1+ 3 Y = \frac{6}{s+3}[/tex]
[tex](s^2+3s)Y'+(s+6)Y=\frac{6}{s+3}[/tex]
And then solve the Y(s) and then use the inverse transform.
But it doesn't yield the correct result. I did the rest on the computer so I guess it's when I apply the transform where I make a mistake.
Thanks for your help.
I think you dropped the negative sign when calculating L[t y''] and L[t y'].
  • · Replies 27 ·
