Help interpreting Voltage equation
  • Thread starter Thread starter EV33
    Voltage
The discussion revolves around the interpretation of the voltage equation Delta V = Delta U/q nat, specifically focusing on the term "q nat" and its implications in the context of electric potential and potential energy.
  • Participants explore the meaning of "q nat" and its role in the equation, with one suggesting it refers to the charge at the location of interest. Others question whether "per unit charge" refers to magnitude only or includes sign, and how this affects the interpretation of potential energy changes.
The discussion is active, with participants providing insights into the relationship between potential energy and charge. Some guidance has been offered regarding the sign of the charge and its impact on potential energy, but there is no explicit consensus on the definition of "q nat."
Participants express uncertainty about the notation and definitions presented in their textbooks, which may influence their understanding of the equation.
EV33
Delta V=Delta U/q nat
My question is what exactly is q nat in this equation?
I am thinking that q nat is the charge at the place where you are trying to find the potential difference. The way my book words it though I am really not sure.
Thank You.
I don't know exactly what that notation means, but the basic idea is that electric potential is potential energy per unit charge. Therefore, if the potential difference between two points in space is [itex]\Delta V[/itex], the total potential energy [itex]\Delta U[/itex] gained or lost by a charge in moving between those two points depends upon the amount of charge that is doing the moving.
So if delta U was positive, and q nat was negative then you would get a negative answer? My book says per unit charge also, and I am not sure if that just means magnitude or if it includes the sign also.
If Delta V is positive (i.e. the ending point is at a higher electric potential than the starting point), then a positive charge moving between those two points will gain potential energy, and a negative charge moving between those two points will lose (the same amount of) potential energy. So, yes, the equation includes the sign of the charge.
Thank you very much.
  • · Replies 18 ·
  • · Replies 22 ·
