Electric field at origin due to 6 charges.
The discussion focuses on calculating the electric field at the origin due to six point charges arranged in a grid. The charges are located at (-0.2m, 0.3m) -2 microC, (-0.2m, 0m) +2 microC, (-0.2m, -0.3m) -2 microC, (0.2m, 0.3m) +2 microC, (0.2m, 0m) +2 microC, and (0.2m, -0.3m) +2 microC. Due to symmetry, the x-component of the electric field (Ex) is confirmed to be zero, while the calculation of the y-component (Ey) requires the application of the formula E=kq/r². Visualizing the charge arrangement and the corresponding electric field vectors is essential for accurate computation.
  • Understanding of electric field concepts and vector addition
  • Familiarity with Coulomb's Law and the equation E=kq/r²
  • Basic knowledge of charge symmetry in electric fields
  • Ability to interpret and draw vector diagrams
  • Calculate the y-component of the electric field at the origin using E=kq/r² for each charge
  • Explore the concept of electric field superposition for multiple charges
  • Learn about the effects of charge distribution on electric field strength
  • Study the principles of symmetry in electrostatics to simplify calculations
Students and professionals in physics, electrical engineering, and anyone interested in understanding electric fields and charge interactions in electrostatics.
MelodyE427
Problem: Charges are located in a gridline figure. The figure has these points: (-0.2m,0.3m) -2 microC, (-0.2m, 0m) +2 microC, (-0.2m,-0.3m) -2 microC, (0.2m,0.3m) +2 microC, (0.2m,0) +2 microC, and (0.2m, -0.3m) +2 microC.
a) Calculate x and y components of the electric field at the origin due to the six charges. (Try to make use of any symmetry that exists before you calculate)
Solution: I feel like the Ex component will be zero because of symmetry but am not completely sure about that because of the positive and negative charges that lie above and below the x axis. As far as the Ey component goes, I'm really unsure how to calculate it. I know to use the equation E=kq/r2 but don't really know where to start from.
Draw a picture of the six charges and draw the vector of the electric field originating from each charge. Remember, the electric field of a point charge at the origin is parallel to the straight line connecting the charge with the origin, and points away from the charge if it is positive, and towards the charge when it is negative.
ehild
10K
12K
