Thread Closed
Light speed measured from distance
Share Thread Thread Tools
Feb4-10, 04:34 PM   #1
Clocks run slower, deeper they are in the gravity field, or faster they are receding from observer.
Question: If we could measure speed of light near the event horizon, or at far away galaxy, by means of measuring from distance, would we measure light going slower there?
I am not asking about measuring speed of light there, or speed of light coming from gravity well, or distant galaxy, and passing us. I am asking what we would measure from here as speed of light there.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb5-10, 03:09 AM   #2
I prefer to define the following quantities (example for diagonal metric, and 1+1 dim):
ds^2 = g_tt*dt*dt - g_xx*dx*dx
physical time differensial: dtau := sqrt(g_tt)*dt
physical length differential: dl := sqrt(g_xx)*dx
physical speed: v := dl/dtau
Since ds^2=0 for light, you will always have v = 1 for light.
However, if you want to calculate |dx/dt| for light, that could be anything depending on your coordinate system. E.g. in Schwarzchild coordinates, radial movement of light towards the origin will have |dr/dt| > 1, since this is just a "coordinate velocity", not physical velocity.
If you define "speed of light" to be my "physical velocity" then you would measure always 1, and this is the most sensible thing to do IMO. If you define it as my "coordinate velocity", then you could get anything you want, depending on your coordinate system.
Torquil
Thread Closed
Thread Tools
Similar Threads for: Light speed measured from distance
Thread Forum Replies
speed of light; distance from earth to sun Introductory Physics Homework 3
Solution to why the speed of light is measured the same by all inertial observers. Beyond the Standard Model 7
Measured speed vs actual speed **very simple** Classical Physics 1
Can light be instantaneous and yet measured as 'c'? Special & General Relativity 9
One way Speed of Light measured by a Single Clock Special & General Relativity 8
