Compute area using divergence and flux?
The discussion revolves around computing the area enclosed by a curve defined parametrically as g(t) = (a cos^3(t), a sin^3(t)), where t ranges from 0 to 2π and a is a positive constant. The problem involves concepts from vector calculus, specifically divergence and flux.
  • Exploratory, Assumption checking
  • The original poster seeks guidance on how to compute the area without a specified vector field F, questioning the relationship between divergence and area. Some participants suggest finding a vector field F such that its divergence equals 1, while others inquire about the reasoning behind this choice.
The discussion is ongoing, with participants exploring the implications of choosing a vector field with a specific divergence. There is a focus on understanding how the divergence relates to the area calculation, but no consensus or resolution has been reached yet.
Participants are working under the constraint of not having a defined vector field F for the area calculation and are questioning the assumptions related to divergence in this context.
nebbie
Compute area using divergence and flux??
Consider the curve given by g(t) =acos^3(t),asin^3(t), where t is [0; 2pi] and a > 0 is a constant.
(a) Find the unit tangent and outward normal vectors.
(b) Compute the area enclosed by this curve.
I have done part a), and I know that
flux of F = divergence x area
but for part b), i m not given a vector field F. so how am I suppose to approach this question and possibly find the divergence (thus the area)? any hint or solution would be much appreciated. ^__^
If you could find an F such the div(F)=1, that would work, right?
why would the divergence be 1? could you be more specific please?
You are going to integrate the divergence over the surface by computing the flux of F around the curve, right? If div(F)=1 then the integral of the divergence is the integral of 1 over the surface. That's the area. So pick ANY F that has div(F)=1. There's lots of choices.
