Change in Entropy of Boiling Water to Steam
  • Thread starter Thread starter ihearyourecho
    Change Entropy
The discussion revolves around calculating the change in entropy when boiling water to steam at a constant temperature of 100 degrees Celsius. The problem involves thermodynamic principles related to heat transfer and phase changes.
  • Participants discuss the formula for entropy change and the necessary parameters, particularly questioning how to properly account for temperature in the calculations.
Some participants have provided clarifications regarding the temperature scale needed for the calculations. There is an acknowledgment of the initial confusion about the temperature's role in the formula.
Participants are working under the assumption that the boiling occurs at a constant temperature, and there is a focus on ensuring the correct application of thermodynamic equations.
ihearyourecho
Find the change in entropy when 2.00 kg of water at 100 degrees C is boiled away to steam at 100 degrees C. Give your answer in kJ/K
deltaS=Q/T
Q=m*Lvaporization
Q=m*Lvaporization
Q=2 kg * 22.6*10^5 J/kg
Q = 4.52x10^6 J
I'm not not sure how to find T though since it's at 100 degrees and going to 100 degrees...
Thanks!
There's a good deal of views on here, does no one know how to do this? ;)
T is given. All you have to do is put it in the correct scale. The denominator in [itex]\Delta Q/T[/itex] is the absolute temperature at which the heat flows into the water.
AM
Oh, I thought I had to do something more complicated with the T. Thanks!
  • · Replies 16 ·
