| Thread Closed |
Electric Field in Concentric Spheres |
Share Thread | Thread Tools |
| Feb7-10, 11:40 PM | #1 |
Two charges concentric spheres have radii of 10.0 cm and 15.0 cm. The charge on the inner sphere is 4.00 x 10 ^-8 C, and that on the outer sphere is 2.00 x 10^-8 C. Find the electric field (a) at r = 12.0 cm and (b) at r = 20.0 cm. 2. Relevant equations I know that this is a fairly simple problem, but am somewhat confused on which numbers I use. Using this equation: ![]() what should I be using for "Q"? At r = 12.0 cm do I use 4.00 x 10^-8 and at r = 20.0 cm do I use 2.00 x 10^-8? Or am I adding the two charges together to get a total charge, since both charges affect each point. Thanks! |
| Feb7-10, 11:51 PM | #2 |
[tex]\int_A E dA=\frac{Q_{enc}}{\epsilon_o}[/tex] Your E field is constant at all points on your surface, so your integral becomes: [tex]E\int_A dA=\frac{Q_{enc}}{\epsilon_o}[/tex] That integral, I hope you see, becomes the total area of your Gauss surface. What is your surface? It is a sphere, so it becomes the surface area of a sphere: [tex]E(4\pi r^2)=\frac{Q_{enc}}{\epsilon_o}[/tex] [tex]E=\frac{Q_{enc}}{4\pi\epsilon_or^2}[/tex] Where Q is the enclosed charge. Does this answer your question? If you do not know what a Gauss surface is, just think of it this way roughly: it's an imaginary surface of any shape(yet often tactically chosen for mathematical ease) that you wrap around a charge to calculate the E field produced by that charge along the surface. So in this problem, we are wrapping an imaginary sphere at r = 12 around the charge. Only the enclosed charge influences the E field. Next, we make an imaginary sphere at r =20. Again, only the enclosed charge adds to the field(and a positive charges cancel negative charges too). Sorry if this explanation is wordy and not to the point. i'm tired, unable to think well, and am going to bed. |
| Feb7-10, 11:56 PM | #3 |
Not really - at both points (12 cm and 20 cm) away, the charge from both spheres affect it, so I should total the charges and therefore use for Qenc, correct?
| Feb7-10, 11:59 PM | #4 |
Electric Field in Concentric SpheresWow sorry for not noting this earlier. This is how you should think about it: the E field in a conductor is zero. Therefore, only the inner sphere affects the E in the area between the two spheres. However, once you exit the outer sphere, both charges affects the E field. |
| Feb8-10, 12:05 AM | #5 |
Ok, and "r" is the distance the point is away from the center, not the radius of the circle, right?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Electric Field in Concentric Spheres
| [SOLVED] another concentric sphere electric field question | Introductory Physics Homework | 3 | ||
| electric field from concentric spheres | Introductory Physics Homework | 4 | ||
| Electric field outside two concentric sphere's | Introductory Physics Homework | 2 | ||
| Electric field due to concentric cylinders | Introductory Physics Homework | 4 | ||
| Electric Potentials: concentric spheres | Introductory Physics Homework | 3 | ||
