| Thread Closed |
The Classic Airplane Problem |
Share Thread | Thread Tools |
| Feb8-10, 09:03 PM | #1 |
A small plane departs from point A heading for an airport 490 km due north at point B. The airspeed of the plane is 210 km/h and there is a steady wind of 50 km/h blowing directly toward the southeast. (a) Determine the proper heading for the plane. ° west of north (b) How long will the flight take? h 2. Relevant equations Law of Sines/Cosines? vf = vi + a*t 3. The attempt at a solution So I drew a picture. You need a velocity vector. This vector must be the sum of the velocity vectors of the wind and the plane, which should also be drawn on the sketch. So I drew a simple sketch showing the plane's northward trek, an angle [tex]\Theta[/tex], another vector showing the wind and the resulting vector. So: The first vector points due North (up), from point A. The wind vector points toward point A, at an angle [tex]\Theta[/tex]. The resultant vector points from point B to the non-pointed end of the wind vector. ...so where in the world does the trig come in? I just don't know where to start plugging in numbers, since this isn't a right triangle it isn't a simple sin/cos problem with the Pythag. Theorem, right? |
| Feb8-10, 11:23 PM | #2 |
Recognitions:
In this problem, AB is the resultant velocity (Vr) of wind velocity (Vw)and proper velocity of the plane (Vp)
To make the problem easy, consider wind direction as x-axis. Angle between wind direction and the resultant is ( 90 + 45) degrees. Let θ be the angle between Vp and Vw. Then if you draw the vectors, you can see that, Vr*sin(135) = Vp*sinθ .....(1) Vr*cos(135) = Vp*cosθ - Vw .......(2) Now solve for Vr and θ. |
| Feb9-10, 08:06 PM | #3 |
Ok I solved for Vr and for theta, but I can't use either of them since there's still the other variable in the equation. IE theta is still in the Vr equation (and I don't know it) and I have Vr in the theta equation. And plugging either equal to each other makes it unsolvable. I end up with a cos (-) plus sin (-).
Vr = Vr [tex]\frac{210 * sin \Theta}{sin (135)}[/tex] = [tex]\frac{210 (cos\Theta) - 50}{cos 135}[/tex] Help? |
| Feb9-10, 08:37 PM | #4 |
Recognitions:
Divide eq. 1 by 2 . You get
(Vp*sinθ) = Vp*cosθ - Vw Square both the sides. You get Vp^2*sin^2(θ) =( Vp*cosθ - Vw)^2 Vp^2*[1- cos^2(θ)] = ( Vp*cosθ - Vw)^2 Now simplify and solve the quadratic to find cosθ. Then find Vr. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: The Classic Airplane Problem
| Analyzing the motion of an airplane based on design specs of the airplane | Introductory Physics Homework | 1 | ||
| classic E&M problem: point charge and a charged sphere, how to analyze this problem | Advanced Physics Homework | 1 | ||
| Classic Mechanics problem. | Introductory Physics Homework | 1 | ||
| Airplane problem >_O | Introductory Physics Homework | 1 | ||
| Airplane problem - help? | Introductory Physics Homework | 2 | ||
