New Reply
Are hollow pipes less likely to bend under weight
Share Thread Thread Tools
Aug1-04, 01:34 PM   #1
Question
I have recently heard a rumor that a hollow pipe can endure a greater load without bending than a solid rod.
Is that true, and why?
Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Aug1-04, 02:28 PM   #2
Recognitions:
Gold Membership Gold Member
No that is not true (at least not as you have stated your question). Here's why:
First thing: Both pipes will bend since neither pipe will have infinite stiffness; under a given load, both pipes will bend some finite amount.
Second thing: The character of the bending depends on the materials used and the geomoetry of the pipes. So it is possible to design a hollow pipe that is stiffer than some solid pipe. However, since you didn't state specifics, I have to assume that both pipes are made of the same material and both pipes have the same outer diameter, d. (I'm also assuming they're round.)
Now we can look more closely at the problem:
The bending stress in the beam (pipe) is given by the following:
[tex] \sigma(x) = \frac{M(x)c}{I} [/tex]
where M(x) is the external moment as a function of x (same for both since loading conditions are the same), c is the distance from the neutral axis (will equal d/2 in this problem when finding the maximum bending stress) and I is the area moment of inertia (aka second moment of area) which is a function of the cross section geometry.
(If you look at the Euler beam bending formula, you will find the same dependence of deflection on moment of inertia, which is the key to this problem.)
The moment of inertia of the solid pipe:
[tex] I_s = \frac{\pi d^4} {64}[/tex]
The moment of inertia of the hollow pipe (same outer diameter, d, along with inner diameter of di):
[tex] I_h = \frac{\pi \left(d^4 - d_i^4\right)}{64} [/tex]
Since the amount of bending is inversely proportional to the moment of inertia, the pipe with the lower moment of inertia will bend more. Looking at the equations you should see that the hollow pipe will bend more.
Aug1-04, 02:53 PM   #3
Recognitions:
A little addendum:
I just realized you may have meant that the loading was solely due to the weight of the pipe. If so, consider the expression for the maximum deflection in a beam under a uniform load (you can get these too if you work out the Euler beam bending equation):
if it's cantilevered:
[tex] \delta_{max} = \frac{qL^4}{8EI} [/tex]
if it's simply supported at both ends (max deflection occurs at center of beam here):
[tex] \delta_{max} = \frac{5qL^4}{384EI} [/tex]
(If you are unfamiliar with the definitions of any of these terms, please ask.) In either case (and assuming both beams are made of the same material (E)), the maximum deflection is proportional to the term q/I.
For the solid beam:
[tex] \frac q I = \frac{\frac{\rho L \pi d^2 g}{4L} }{\frac{\pi d^4}{64}} = \frac{16\rho g}{d^2} [/tex]
For the hollow beam:
[tex] \frac q I = \frac{\frac{\rho L \pi \left(d^2-d^2_i\right) g}{4L} }{\frac{\pi \left(d^4-d^4_i\right)}{64}} = \frac{16\rho g}{d^2+d_i^2} [/tex]
Assuming I haven't messed up my math here, the bending for the hollow beam is less than the bending for the solid beam. The solid beam is still more stiff, but it also undergoes more loading (because the solid beam weighs more). I hope that helps.
Aug1-04, 06:12 PM   #4
Recognitions:
Retired Staff Staff Emeritus
What you may have heard is this, Nicholas:
Between a solid pipe and a hollow pipe of the same weight, the hollow pipe will be more resistant to bending. It will also have a much larger radius.
Mar17-10, 01:53 AM   #5
Quote by enigma View Post
From the equations already presented above, the maximum bending moment is proportional to:
[tex]d^4 - d_{i}^4[/tex]
The mass of the pipe is proportional to the cross-sectional area which is proportional to difference in the squares of the outer and inner radius (or diameter since our constant [tex]K[/tex] is arbitrary), so we can set that equal to constant and eliminate either the outer or inner diameter from our equation:
[tex]d^2 - d_{i}^2 = K[/tex]
[tex]d_{i}^2 = d^2 - K[/tex]
[tex]d_{i}^4 = d^4 - 2Kd^2 + K^2[/tex]
[tex]d^4 - d_{i}^4 = 2Kd^2 - K^2[/tex]
Thus for a constant mass, we see the bending moment of a pipe is quadratically proportional to the outer diameter:
[tex]2Kd^2 - K^2[/tex]
Not accounting for other factors such as localized shear stress, compression load if employed as a vertical structural beam, etc, the larger the diameter hollow pipe, will have a quadratically higher maximum bending moment than a small diameter hollow pipe of the same mass.
This moment property is conceptually related to the physics of the ratio of lengths of fulcrum or ratio of length to height of a truss, visualize the diameter of the pipe as the short side of the fulcrum, where forces are more concentrated the shorter the short side relative to the long side.
A solid pipe of equivalent constant mass, would be limited to an outer diameter of [tex]\sqrt{K}[/tex], because [tex]d_{i} = 0[/tex].
If I have misstated, please free to post a correction. Hope my input is helpful.
Example: compare a Schedule 40 2.5" pipe, which has an outside diameter of 2.875", inside diameter of 2.469", and wall thickness of 0.203", to a Schedule 10 3.5" pipe, which has an outside diameter of 4.0", inside diameter of 3.760", and wall thickness of 0.120". The 4" pipe has 14% less mass, but comparing [tex]d^4 - d_{i}^4[/tex] has 80% higher maximum bending moment before elasticity stress failure.
Another example with maximum bending moment calculation for GI pipe mast (30 Ksi yield strength):
http://en.wikipedia.org/wiki/Second_..._cross_section
20' x 4" Sched 5 (1/12" wall), 15T load, 32 kg, 28T@100" bending
20' x 4" Sched 5 (1/12" wall), 28T load, 67 kg, 28T@100" bending
(3 Ksi concrete filled with 3" hollow or pvc pipe center)
20' x 2.875" Sched 10 (1/8" wall), 15T load, 32 kg, 14T@100" bending
20' x 2.875" Sched 5 (1/12" wall), 11T load, 23 kg, 10T@100" bending
T is tons
May2-11, 02:17 PM   #6
out of two materials, a solid rod and a hollow pipe, both of similar dimensions and similar loading which of the two will have lower bending stresses, essentially explaing is a high bending stress a good or bad occurance
May9-11, 06:09 AM   #7
just calculate it using the formulas above, work it out for an I value of a hollow section, and then for a solid I value and compare them and see which is most suitable to your design requirements.
high bending stresses are generally a bad occurance. what you should relate a high bending stress to is the safety factor, always work about 2 - 4 safety factor in machinery design. safety factor is the (yield stress of material/bending stress)
New Reply
Thread Tools
Similar Threads for: Are hollow pipes less likely to bend under weight
Thread Forum Replies
Car negotiating a bend... Introductory Physics Homework 25
why does it bend Classical Physics 0
Hollow Earth, Hollow Gravity General Discussion 22
Carbon Steel Pipes to API 5L Grade B Standard Weight Mechanical Engineering 1
how pipes in parralel works in comparison to pipes in series Classical Physics 3
