What Is the Frequency of the Tuning Fork in a Resonating Water Tube Experiment?
  • Thread starter Thread starter dagitt
    Physics Waves
The discussion focuses on calculating the frequency of a tuning fork in a resonating water tube experiment and the time it takes for a sound to travel from the bottom of a well. The key equations used include V = f * Wavelength for frequency calculations and T = 1 / f for period determination. The speed of sound is established at 340.29 m/s. The correct approach involves understanding standing waves, where resonance occurs at specific points in the tube, rather than directly using the water depth as a wavelength.
  • Understanding of standing waves and resonance
  • Familiarity with the wave equation V = f * Wavelength
  • Knowledge of basic physics concepts related to sound speed
  • Ability to solve problems involving distance, speed, and time
  • Study the principles of standing waves and resonance in tubes
  • Learn how to apply the wave equation V = f * Wavelength in practical scenarios
  • Explore the relationship between sound speed and depth in fluid dynamics
  • Practice problems involving time calculations for sound travel in different mediums
Students in physics, educators teaching wave mechanics, and anyone interested in sound propagation and resonance phenomena.
dagitt
1. A vertical tube with a tap at the base is filled with water, and a tuning fork vibrates over its mouth. As the water level is lowered in the tube, resonance is heard when the water level has dropped 20 cm, and again after 60 cm of distance exists from the water to the top of the tube. What is the frequency of the tuning fork?
2. If you drop a stone into a well that is d = 129.5 m deep, as illustrated in the figure below, how soon after you drop the stone will you hear it hit the bottom of the well?
V = f * Wavelength
(f = frequency in Hz)
T = 1 / f
(T =period in sec.)
Speed of sound = 340.29 m/s
1. i just don't understand it..i'm assuming the 20cm and 60cm are wavelengths? why am i given two? if i plug these into the equation V = f * Wavelength (using speed of sound for V), i get 2 different answers...and according to my webassign, neither are right. i think I'm doing something wrong, because i generally just don't understand how to set up this prob.. :(
2. Wavelength = 129.5 m, V = 340.29 m/s. Solve for frequency.
F = 2.63 Hz, plug into Period Formula.
T = .38 sec. But this is the wrong answer according to Webassign.
any or all help appreciated. i really just suck at anything math related.
thanks so much
1) Have you studied standing waves yet? If not you'll need to look them up as they're the key here.
Look at this standing wave;
http://www1.union.edu/newmanj/lasers/Light%20as%20a%20Wave/standing%20wave2.JPG
The resonance will occur when the wave hits the water on a maximum, i.e after 1/4 of a wavelength, and after 3/4 of the wavelength, do you see why?
2) The wavelength is not 129.5m, there's no reason why it should be. I can't see any reason why you'd need to consider frequency/wavelength here, use the simple relation time = distance / speed
9K
