Register to reply
Adding up resistors
by magnifik
Tags: adding, resistors
Share this thread:
magnifik
#1
Feb10-10, 03:25 PM
P: 361
i'm a noob, and i am having trouble adding resistors. this circuit can be reduced to 1 resistor. what is its value?
2. Relevant equations
parallel: 1/Rtot=1/R1+1/R2+1/R3+1/R4
series: Rtot=R1+R2+R3+R4
3. The attempt at a solution
so i thought 3, 2, 2 added up in series and you just do 6/8+1/4, but this isn't right. =/ i'm having trouble discerning which resistors are parallel and which are in series. any help would be appreciated.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
willem2
#2
Feb10-10, 04:36 PM
P: 1,398
2 resistors R1 and R2 are in series if one connector of R1 is connected to a connector of R2 and nothing else is connected to these connectors. (or if you can determine that no current can flow through such a connection)
None of the resistors here is in series with any other.
The 3 ohm resistance isn't in series with any of the 2 ohm resistances because the point between the 3 ohm resistance and any of the 2 ohm resistances is also connected to the other 2 ohm resistance
2 resistors are parallels if one connector of R1 is connected to a connector of R2 and the other connector of R1 is connected to the other connector of R2. There's only 1 pair of
resistances here thats parallel.
The direction they are drawn in doesn't matter.
Once you combined those resistances, you can look again for a pair of resistances that is in series or parallel.
magnifik
#3
Feb10-10, 05:03 PM
P: 361
huh? so are you saying i can disregard the 3 Ohm resistor?
i know the answer is supposed to be 2. i don't know how to get there though.
willem2
#4
Feb10-10, 05:10 PM
P: 1,398
Adding up resistors
Quote Quote by magnifik View Post
No. I said the 3 ohm resitor isn't in series with any of the 2 ohm resistances. What you have to do is find the pair of resistances that's parallel, combine those and then look for other series of parallel pairs
magnifik
#5
Feb10-10, 05:21 PM
P: 361
is 3 parallel with 4 and 2 is parallel with 2?
Register to reply
Related Discussions
Adding up resistors Introductory Physics Homework 4
Two unknown resistors. Need to find values of resistors. Introductory Physics Homework 8
Led & resistors Electrical Engineering 16
Color codes there is gold (5%) and silver (10%) for tolerence General Physics 2
Adding General Discussion 23
