Thread Closed
Engineering problem (uses stress, strain, Young's Modulus)
Share Thread
Feb10-10, 10:04 PM   #1
2. As engineers, we wish to use a metal bar as a support arm on a crane. The bar has a
Young’s Modulus of 3x106psi . Assuming the rod will need to be 3ft long. Answer the
following questions…
a)If the crane is designed so that the
maximum tensile force on the rod is predicted to be
160,000 lbs, what should the cross sectional area of the rod
be to have a strain less than 0.001? _________
b) There was an accident at the worksite and the crane needs to lift a
600,000 lbs boulder to rescue some workers. If the bar has an Ultimate Tensile Strength
of 6400psi and the bar supports all of the weight , how much can the
crane actually lift?
__________
2. Relevant equations
stress= force/ area (sq.in.)
UTS= weight where a rod breaks/cross sectional area
Strain=extension/original length
YM=stress applied/strain induced
3. The attempt at a solution
I tried everything seemling, but I cant figure out where to plug in everything to get an answer that makes sense. I would really appreciate it if someone can walk me through it (I'm really good at math, but ive never taken physics, and this is my first engineering class, so I am understandably a little lost)
thanks alot
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Thread Closed
Similar discussions for: Engineering problem (uses stress, strain, Young's Modulus)
Thread Forum Replies
true stress/strain modulus Engineering, Comp Sci, & Technology Homework 0
stress and strain. young modulus Engineering, Comp Sci, & Technology Homework 10
Youngs modulus stress/strain. Introductory Physics Homework 2
Young's Modulus and the strain on a sphere due to a uniform pressure Advanced Physics Homework 3
Young's modulus problem -- need a hint Introductory Physics Homework 2
