Magnitude and direction of its velocity problem
The discussion focuses on calculating the magnitude and direction of a soccer ball's velocity after being kicked with an initial speed of 5.9 m/s at an angle of 24.0° above the horizontal. At 0.250 seconds, the velocity components are determined using the equations vx = v0x + ax * t and vy = v0y + ay * t, leading to a horizontal velocity (vx) of 5.4 m/s and a vertical velocity (vy) of 0.29 m/s. The overall velocity magnitude is calculated using the Pythagorean theorem, and the direction is found using the arctangent function. The discussion emphasizes the constant x-direction velocity and the changing y-direction velocity due to gravity.
  • Understanding of projectile motion principles
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of kinematic equations for motion
  • Basic grasp of vector addition and components
  • Study the derivation of projectile motion equations
  • Learn about the effects of air resistance on projectile motion
  • Explore advanced kinematics involving multiple dimensions
  • Investigate real-world applications of projectile motion in sports
Students studying physics, educators teaching kinematics, and sports analysts interested in the dynamics of projectile motion in soccer.
Quezar
A soccer ball is kicked with an initial speed of 5.9 m/s in a direction 24.0° above the horizontal. Find the magnitude and direction of its velocity at the following times. (Take the +x axis to be parallel to the ground, in the direction that the ball is kicked.)
(a) 0.250 s after being kicked
1 ___ m/s
2 ___ degrees (counterclockwise from the +x axis)
(b) 0.500 s after being kicked
1 ___ m/s
vx = v0x +ax * t
vy= v0y + ay * t
cos24=x/5.9
1/2*-9.8*.25^2+2.4*.25 = .29
vx = 5.4 vy = .29
thats all I could figure out
you are given the initial velocity and theta , you can get vox and voy noting that:
vox = vo*costheta , voy = vo*sintheta .. and in each part you given the time (t) , another thing you need to notice is that the velocity in the x-direction is constant, so what that tells you?
and the velocity in the y-direction is changing under the influence of gravity, you wrote this equation:
vy = voy -gt , you have voy , g is constant , and you are given t..
to find v it is just finding sqrt(vx^2 + vy^2) and the direction is just arctan(vy/vx) ,this question is fairly straight forward, try again and see if it is different than the values you got .. :)
11K
