How Does a Voltmeter's Resistance Affect Voltage Measurement Accuracy?
The discussion revolves around the impact of a voltmeter's resistance on voltage measurement accuracy within a specific circuit context. Participants explore concepts related to circuit analysis, including the application of Kirchhoff's laws and the role of the voltmeter in the circuit.
  • Homework-related
  • The original poster (OP) presents a problem involving a voltmeter with a specified resistance and full-scale voltage, seeking guidance on the expected reading and percentage error.
  • Some participants emphasize the necessity of showing calculations to facilitate assistance, noting that forum rules require this for effective help.
  • One participant suggests establishing a relationship between the voltages in the circuit, specifically between 3Vb and Vb, to aid in solving the problem.
  • Another participant highlights the importance of considering the voltmeter as part of the circuit when making measurements, recommending that it be included in the schematic for accurate analysis.
  • A later reply comments on the lack of recent engagement from the OP, indicating a broader effort to maintain the forum's quality by prompting users to provide more context in their posts.
Participants generally agree on the importance of including the voltmeter in the circuit analysis. However, there is no consensus on the specific calculations or methods to be used, and the discussion remains unresolved regarding the OP's specific questions.
Limitations include the OP's lack of detailed calculations and the absence of a schematic diagram, which may hinder the ability to fully analyze the problem. Additionally, the discussion does not clarify the assumptions regarding the circuit configuration or the voltmeter's influence on the measurements.
rey242
A voltmeter will be used to measure the voltage vA in the circuit below. Assume that the voltmeter has a resistance of 100[ohms] and a full-scale voltage of 20[V].
a) What will the voltmeter read?
b) What is the percentage error in making this reading?
Several equations
(i.e KVL, KCL, Ohm's law, Voltage Divider, Current Divider, etc.)
I have a general idea on how to do this but I'm not sure if about a few concepts...
I'm pretty sure that there is no current through the 7 volt source.
I think you can figure Vb can be figured out through KVL but I am not sure.
If I cant, then I have to use one part of the circuit to find vb.
Can you check to see if these concepts are correct?
You MUST show some work (calculations). We can't help if we don't know exactly where you are stuck and forum rules prohibit our just giving you an answer.
In my opinion you have to find a relationship between 3Vb and Vb.
Also, you have to know how to compare the voltmeter readings with the actual voltage which you have to find.
When you are making a voltage measurement, the voltmeter becomes part of the circuit. So, draw it in on the schematic to include its effect.
Since the OP hasn't been here in 10 years I doubt we are going to get an updated drawing. I made my post as part of a general cleanup we are doing on old posts and to alert new members who find this post via a Google search that we require some work.
:oops::oops:
