Why Do Some Stars Explode?
  • Context: Graduate
  • Thread starter Thread starter Antonio Lao
    Stars
The discussion centers on the reasons behind stellar explosions, particularly in relation to the Chandrasekhar limit and various theoretical models. Participants explore concepts related to stellar mass, gravitational collapse, and the implications of different physical laws.
  • Some participants propose that stars explode due to exceeding the Chandrasekhar limit, while others argue that such stars collapse under their own gravity and may become black holes.
  • A hypothesis is presented suggesting that an intrinsic metric variable related to velocity components may determine whether a star explodes.
  • Discussion includes the relationship between remaining mass after an explosion and the formation of neutron stars or black holes based on the Chandrasekhar limit and neutron degeneracy limit.
  • The Schwarzschild radius is introduced as a critical factor in defining when an object becomes a black hole.
  • Mathematical models are suggested to support various theories, with participants expressing interest in further mathematical development.
  • Fundamental conservation laws such as time symmetry in energy and translational symmetry in momentum are discussed in relation to metric invariance.
Participants express differing views on the mechanisms behind stellar explosions and the implications of mass limits, indicating that multiple competing models remain without consensus.
There are unresolved mathematical steps and assumptions regarding the proposed models, particularly in relation to the intrinsic metric variable and its implications for stellar behavior.
Antonio Lao
Why do Some Stars Explode ?
It is a fact that stars do explode. But why? Cosmological theory says it is caused by the acquisition of mass beyond the Chandrasekhar limit. My hypothesis is that explosion is related to an intrinsic metric variable. This variable is the parameter for all possible velocity components attributed to a star. If the vector sum of all these components is zero, the star will explode.
Astronomy news on Phys.org
stars with a mass beyond the chandasekhar limit do not explode but collaspe uder the force of there own gravity because they burn there fuel to quickly. now these stars generally become black holes.
but i would still like to see your maths to support this antonio.
regards jamie
They are overweight. Obesity is a universal health risk. Stars over the Chandrasekhar limit do tend to explode. But, will not collapse unless the mass remaining after exploding is over the Chandrasekhar limit. If the remaining mass is over the Chandrasekhar limit [~1.44 solar masses] but less than the neutron degeneracy limit [~ 3 solar masses], a neutron star will form. Black holes form if the remaining mass exceeds the neutron degeneracy limit.
hello chronos
thanks for clarifying that point. yet another thing I've learnt.
can you please tell me were the shwartzchild radius fits into this.
many thanks
jamie
The Schwarzschild radius describes the event horizon of a black hole. Another way of putting it is the Schwarzschild radius is the size at which an object of any given mass becomes a black hole. So, an object is not a black hole so long as it is larger than the Schwarzschild radius for its mass.
I'll be working on the math in conjunction with the other theory development in progress. I'll post it as soon as I get it together. Am requesting for your patience.
jamie,
Just an overview of the physical concepts for setting the math in a model of metric invariance.
Time symmetry in energy, translational symmetry in linear momentum, rotational symmetry in angular momentum are the three fundamental conservation laws.
Linear momentum is a function of velocity ([itex]p=mv[/itex]) so is angular momentum ([itex]L = mvr[/itex]). Force is a function of linear momentum ([itex]F= \frac{dp}{dt}[/itex]). but energy is the product of force and a metric.
If we assume that mass=1, then [itex]p=v, L=vr, F=\frac{dv}{dt}[/itex]. But [itex]\frac{dv}{dt}[/itex] is just acceleration, therefore F=a and Energy is just the product of generalized acceleration and a metric.
The metric invariance is then given by
[tex]\vec{a} \cdot \vec{r} = c^2[/tex]
where c is the speed of light in vacuum.
From this metric invariance, we can define a quantum magnitude for acceleration as
[tex]\left| a_n \right| = \frac{c^2}{nl_p}[/tex]
where [itex]l_p[/itex] is the Planck length.
thank you antonio
I will work thruogh you math and let you know how i get on
regards jamie
  • · Replies 48 ·
  • · Replies 77 ·
10K
  • · Replies 17 ·
  • · Replies 17 ·
21K
  • · Replies 28 ·
