How to solve Pell's equation using Alpertron's online calculator
  • Context: Undergrad
  • Thread starter Thread starter mrdex
The discussion revolves around solving Pell's equation of the form x² - Dy² = 1, specifically for integral values of D that are not perfect squares. Participants explore methods to find minimal integer solutions for x and y, including the use of continued fractions and online calculators.
  • Homework-related
  • One participant expresses confusion about finding minimal integer solutions for the Pell equation and mentions the Mathworld page as unhelpful.
  • Another participant questions the definition of "minimal" and suggests that positive integer solutions are likely sought.
  • Some participants propose that rational approximations to √D could yield solutions, noting that x/y values near √D appear to work in several cases.
  • A participant explains how to calculate square roots using continued fractions and provides a detailed method for deriving the continued fraction representation of √D.
  • Further clarification is offered on how to handle cases where the period of the continued fraction is even, indicating that this affects the calculation of x and y.
  • One participant shares their success in creating a program to find minimal values of x and y and expresses uncertainty about the significance of the even k condition.
  • Another participant discusses the relationship between minimal solutions and generating further solutions to Pell's equation, referencing specific examples and calculations.
  • A problem involving the equation x² - 97y² = -1 is introduced, hinting at a method for finding solutions.
  • A final suggestion is made to use an online calculator for solving Diophantine equations, which may aid in finding solutions for Pell's equation.
Participants express varying levels of understanding regarding the methods for solving Pell's equation, with some agreeing on the utility of continued fractions while others remain uncertain about specific steps. The discussion does not reach a consensus on the best approach or the significance of certain conditions.
Participants mention limitations in their understanding of continued fractions and the implications of the period length in calculations, indicating that further exploration is needed to fully grasp these concepts.
mrdex
Ok, I've done a lot of searching and looking around but I cannot find anything that I can make sense of. The Pell equation I want to solve is this:
[tex]x^2 - Dy^2 = 1[/tex]
Given an integral value for D that is not a square number, find the minimal values of x and y where x and y are both integers.
I've seen stuff about using continued fractions or finding values for x and y once given the minimal values of x and y but I can't make head nor tale of it all. The Mathworld page on Pell equations gives a lot of information but most of it is irrelevant. Near the bottom they show a table of the results I want to achieve but they don't mention how those values in the table were found. Any ideas?
what do you mean by minimal ? I don't know a whole lot about this, but I'm guessing you are looking for positive integer solutions.
Else the minimal solution is (1,0) for all D...but I think that's not what you want !
Also, it looks like x/y near sqrt(D), gives you x,y for all the cases I tried (7 or 8). So looking for rational approximations to sqrt(D) may be the way to go. Perhaps, that's where the continued fractions come in.
D=2, sqrt(D) = 1.4142... x/y=3/2 = 1.5
D=3, sqrt(D) = 1.732 ... x/y=7/4 = 1.75
D=5, sqrt(D) = 2.24 ... x/y = 9/4 = 2.25
etc.
Hi, you'll have to learn how to calculate square roots with continued fractions.
Since formatting continued fractions is a nightmare of parentheses, I'll refer you to http://mathworld.wolfram.com/ContinuedFraction.html and ask you to read equation (3), which gives the basic form of the continued fractions we'll need and the shortcut form for this (4) so I don't scratch my eyeballs out trying to format things. Also see (11) for the finite version of this. Another bit of slightly confusing notation, [x] will mean the greatest integer less than x. This shouldn't be confused with our continued fraction notation, since that will always have more than one term.
Assume D is not a perfect square. To find the continued fraction expression of [tex]\sqrt{D}[/tex], we first set [tex]a_{0}=[\sqrt{D}][/tex]. This is a very crude approximation to [tex]\sqrt{D}[/tex]. At this point we have [tex]\sqrt{D}=a_{0}+(\sqrt{D}-a_{0})=a_{0}+\frac{1}{\frac{1}{\sqrt{D}-a_{0}}}[/tex]
We apply the same procedure to [tex]\frac{1}{\sqrt{D}-a_{0}}=\frac{\sqrt{D}+a_{0}}{D-a_{0}^{2}}[/tex] and get [tex]a_{1}=[\frac{\sqrt{D}+a_{0}}{D-a_{0}^{2}}][/tex]
Now we have [tex]\sqrt{D}=a_{0}+\frac{1}{a_{1}+(\frac{\sqrt{D}+a_{0}}{D-a_{0}^{2}}-a_{1})}[/tex]
Now [tex]a_{2}=[\frac{1}{\frac{\sqrt{D}+a_{0}}{D-a_{0}^{2}}-a_{1}}][/tex]. Continue to get the rest of the a's. Eventually you'll get something that repeats like [tex]\sqrt{D}=[a_{0}, a_{1}, \ldots, a_{k}, a_{0}+\sqrt{D}][/tex]
Heres where you stop. If k is odd find integers x and y where [tex]x/y=[a_{0}, a_{1}, \ldots, a_{k}][/tex]. These are your minimal solutions to Pell's equation. If k is even, you do something similar, I'm not positive exactly what, sorry. I'll hopefully come back tomorrow with an answer.
An example: D=14
[tex]a_{0}=[\sqrt{14}]=3[/tex] so [tex]\sqrt{14}=3+\frac{1}{\frac{1}{\sqrt{14}-3}}[/tex]
[tex]a_{1}=[\frac{1}{\sqrt{14}-3}]=[\frac{\sqrt{14}+3}{5}]=1[/tex]
So [tex]\sqrt{14}=3+\frac{1}{1+(\frac{\sqrt{14}+3}{5}-1)}=3+\frac{1}{1+\frac{1}{\frac{1}{\frac{\sqrt{14}+3}{5}-1}}}[/tex]
[tex]a_{2}=[\frac{1}{\frac{\sqrt{14}+3}{5}-1}]=[\frac{5}{\sqrt{14}-2}]=[\frac{\sqrt{14}+2}{2}]=2[/tex]
So
[tex]\sqrt{14}=3+\frac{1}{1+\frac{1}{2+(\frac{\sqrt{14}+2}{2}-2)}}[/tex]
ok I'm stopping here. Go a couple more steps and you'll get [tex]\sqrt{14}=[3,1,2,1,3+\sqrt{14}][/tex], so we've started to repeat.
Now find [tex][3,1,2,1]=3+\frac{1}{1+\frac{1}{2+\frac{1}{1}}}=15/4[/tex], so x=15 and y=4 are the minimal solutions in this case.
I figured out what to do when k is even. I knew it involved doubling the period or something similar, but it wasn't working out. Sorry for the confusion.
Anyhoo, ionce you get to [tex]\sqrt{D}=[a_{0}, a_{1}, \ldots, a_{k}, a_{0}+\sqrt{D}][/tex] and k is even, you need to find x, y with [tex]x/y=[a_{0}, a_{1}, \ldots, a_{k}, 2a_{0}, a_{1}, \ldots, a_{k}][/tex], then x, y are your minimal solutions.
The [tex]2a_{0}[/tex] term shouldn't be suprising. If you were at [tex]\sqrt{D}=[a_{0}, a_{1}, \ldots, a_{k}, a_{0}+\sqrt{D}][/tex], and you wanted to find more terms, you'd see [tex]a_{k+1}=2a_{0}[/tex]. Muck about with a few examples and you'll see why this is so.
Ok thanks very much shmoe. I should be able to figure it out from there :smile:.
You're welcome :smile: . Feel free to ask any questions if you need clarification. Also, if you want details on how to generate all solutions from the minimal one, just ask.
Just to let you know that I managed to make a program which finds the minimum values of x and y given a value of D thanks to your explanation. I would definatley have gotten stuck on the if k is even thing. I still don't understand why it should make a difference. Anyway thanks again :smile:.
Glad it worked for you.
If you truncate after the first period you get [tex](-1)^{k+1}[/tex].
If you try D=10, you'll get [tex][3,3+\sqrt{10}][/tex]. If you take [tex]x/y=3/1[/tex] then you get
[tex]3^2-10\cdot 1^2=-1[/tex]
but if you go to [tex]x/y=[3,6]=3+1/6=19/6[/tex], you get:
[tex]19^2-10\cdot 6^2=1[/tex]
Notice [tex](3+\sqrt{10})(3+\sqrt{10})=19+6\sqrt{10}[/tex], this is no accident! You can get the rest of the solutions to Pell's either by finding more periods of your continued fraction or by finding powers of your minimal solution.
Here is a nice problem, within reach of a programmable calculator too.
[tex]X^2-97Y^2=-1.[/tex]
Hint:.. here is the expansion,
{9,1,5,1,1,1,1,1,1,5,1,(18)}
Try http://www.alpertron.com.ar/QUAD.HTM
It noy only presents a general method of solving Diophantine equations [tex]Ax^2 + Bxy + Cy^2 + Dx + Ey + F = 0[/tex] (click on 'methods') but has also a good calculator.
11K
  • · Replies 17 ·
  • · Replies 20 ·
